Putting 6x9 speakers behind the seat
I thought I remembered post from times past that someone was able to modify the factory behind the seat brackets to install 6x9 speakers. Has anyone done this?
Any reccommendations for a reasonably priced CD player w/ MP3 input? I don't mind cutting the dash. I use my truck working on my rentals in the hood, so I'm not looking for anything too nice. |
Parts and more parts
Re: Putting 6x9 speakers behind the seat
GM used to sell corner pieces that you put 6X9 speakers in the corner of the 81 through the 87 Chevy trucks.
Insert Witty Text Here
The only GM pieces I have seen were for 4X10 speakers, but that does not mean they did not offer anything else. The 6X9 brackets were widely produced at one time by the aftermarket, but I have never been able to locate any new ones. I have a pair that I found after a couple of years of searching junkyards.
A friend was able to mount 6X9 speakers to the factory 4X10 mounts by reversing the left and right brackets. That repositioned the speakers enough to allow more room for the larger 6X9 magnets to clear the cab. He just bolted the 6X9 speakers to the 4X10 holes as best he could. I talked to a stereo installer on another board several years ago. He said he made them from 3 pieces of MDF. There ws the one that the speaker mounted to that screwed to the side and back of the cab at 45 degree angles along with top and bottom plugs to seal up the opening. Slonaker |
I used stock 4x10 brackets, cut em to fit in the 6x9s. I'll try to get some pics if you want.
As for a decently priced CD player with MP3 input I got a Sony from wal-mart. It was about $120. http://www.walmart.com/catalog/produ...uct_id=5148256 I was happy with it, pulled it out of my blazer before I sold it. Im considering putting in in my 07 Tahoe...
Anthony 07 Tahoe LT 70 Chevelle 450HP 383-TH400 77 GMC Royal Sierra~Resto in progress~ |
i did it b4 i used some 1x6 and cut between 40-45 degree down the sides, i think the 45 was to deep of angle
My son's truck (86 Chevy Silverado) has two metal pieces (one for each side)that came from over the GM parts counter that hold 6X9 speakers, they mount down low in the corner of the cab, by the seat belt housings. These pieces are enclosed and fit along the inside of the cab's metal work. I have seen them in other trucks, also. We purchased them from the dealer and are still using his.
#7 | |
The adapter plate would look like poopy -- better to get one of those full screen kenwood dvd/gps rigs ![]() |
#8 | |
yeller
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#9 | |
The Crazy Machanic
![]() cant really see them pass the subs ill have to get another picture
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) ![]() * 1970 chevelle 2dr sedan Latest update June 24 2007. ![]() *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) ![]() newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one ![]() |
Thanks for the help.
Happy to be here
![]() Join Date: Mar 2000
Look on eBay. I see the corner brackets there all the time.
This is my factory 4X10 bracket.
![]() This is one of the aftermarket 6X9 brackets I got from a junkyard truck. I assume it is aftermarket since it has no markings on it, but it could be the item piecesparts is talking about. ![]() Slonaker |
#13 |
there easy to make with plywood,particle board.mock something up out of card board if you can't visualize it.i just made a face plate for the speaker to screw to,then a wedge shaped box,triangle..screwed it down with a couple of small L brackets.covered it in dynamat.looks good and sounds great.makes a great box for the bass sounds.
" Never look up a dead dogs butt." ![]() |
#14 |
I have the exact ones Slonaker has posted. I was lucky enough to get them from a local stereo shop while they still made them. Later when I asked him if they still had them whe Slonaker was looking for his, he told me that they did not carry them any more. They only had some cheap plastic ones because too many people were cutting themselves while installing these.
![]() Last edited by Ric83; 08-30-2007 at 11:11 AM. |
#15 | |
The truck is a hundred miles down the road, but when we purchased them, I did not cut them to fit the 6"X9" speakers, they were already that size. They came from GM that way. As I stated, they mount to the floor of the cab on the bottom end and the top is screwed to the metal inner liner of the cab corner and they are made of metal. Their mounting creates a corner box effect and works reasonably well. However, if you have the 4" by 10", you might make them work for a 6"X9" or at least use it as a pattern. The ones that I have are shaped something like Slonaker's picture, but are completely flat across the front (which goes from the back wall to the door jamb) and holds a 6"X 9" speaker without any cutting. To be honest, the 4" X 10" designed speakers are not a normal thing where I have been looking. Last edited by piecesparts; 08-30-2007 at 11:45 AM. |
#16 |
![]() Join Date: Jun 2007
My 86 has 6x9s in the corners behind the seat. They were installed at a stereo shop here in Springfield when the previous owner had my truck. I can take some pictures tomorrow if you want to see them. ...Joe
I'm not speedin'! I'm qualifyin'! |
#17 |
>130dB Moderator
Gm made a 6x9 bracket. I had them in ym truck when I got it. Just some crap sheet metal, not worth a crap for mounting speakers into.
What I have now is a little better anyway.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
#18 |
Dark Heart Motorsports
you can modify the back holding bracket to fit 6x9s...it will be a lil flimsy at the sides, but you could always reinforce that with fiberglass, resin, and about 30 toothpicks for braces
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
#19 |
i did it in my 81 chevy truck but i had to put the brackets on opposite sides so speakers wold not touch cab but it works
#20 | |
2004 Silverado Crewcab (Dark Spiral Gray) |
#21 |
Slots go on anything!
Or you can do this: http://67-72chevytrucks.com/vboard/s...d.php?t=287987
. These brackets are really nice, heavy pieces. |
#22 |
yup, have a set in mine, one of my favorite upgrades, fit perfectly
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
#23 |
Yes they do...And you can hear the speakers without a 100,000 watt amp..
#24 |
I made triangular boxes out of thin MDF and painted them black. I installed regular round speakers (4"?) but you could put larger speakers in them also - just cut the face plate to the size of your speaker. I then built a triangular storage box out of oak plywood for miscellaneous stuff and a cushioned place to transport a 4' level without it getting beat up. I will post pics if you want. It worked out well for me.
#25 |
i bought 6x9 boxes then cut them thinner to fit. Worked well this way because i was able to get the speaker outside the seat(firing past) instead of muffled behind the seat. i will take a picture, worked better than i originally intended.
