Old 10-21-2007, 12:53 PM   #1
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
front spring removal...Dangerous??
I got my drop springs from a board member this weekend. (thanks Barrett!)
And I got the rears in no problem. Now for the front. I was reading the manual and it says.The spring is under great pressure and could cause injury My wife read it too and said "That thing will Boi-oi-oing out of there and cut your head off!"
Is this something my modest mechanical abilities can tackle or am I flirting with disaster?
BTW Barrett took time out of packing and moving his family to drive and meet me with springs...Very Cool!
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 10-21-2007, 01:00 PM   #2
mkhutch
Throbbing Member
Re: front spring removal...Dangerous??
Yeah what you need are some spring compressors. You can buy/rent them from your local auto parts store. Put them on and tighten the nut up and it will stay compressed as you remove it.
mkhutch is offline   Reply With Quote
Old 10-21-2007, 01:12 PM   #3
Brad
Out of the carpool lane.
Brad's Avatar
Always wrap safety chains around the spring and the control arm when removing them. This way if the spring gets loose, it won't go far. Btw, don't wrap the chain tight but leave some slack to work with. I had a spring get loose on me and it's not going to go far but can do alot of damage if not chained down and/or fingers get in the way.
Btw, I just used a jack under the control arm and slooooowly let the spring pressure off. No need for spring compressors.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 10-21-2007, 02:21 PM   #4
Fastfun
Fastfun's Avatar
What Brad said
Fastfun is offline   Reply With Quote
Old 10-21-2007, 02:45 PM   #5
dave2953
Dave's not here, man
dave2953's Avatar
I've had mine out several times and only used a jackstand and a floor jack. Never had any problems. Just lower the jack down SLOWLY and you'll be fine.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 10-21-2007, 02:56 PM   #6
Yeller68
Active Member
Yeller68's Avatar
Triple agree with Brad. Used a floor jack, let off slowly, and also had a chain dropped through the control arm, and through the middle of the spring. Piece of cake, just remember slow and easy letting off on the jack.
Yeller68 is offline   Reply With Quote
Old 10-21-2007, 04:16 PM   #7
retodd7711
retodd7711's Avatar
Unhappy Re: front spring removal...Dangerous??
here's how she sits on the 4" rear drop front stock. I measured the bumper before and after. It only dropped it 2" that's how worn out the old springs were!
Here's my "helper" on a Sunday afternoon
She can't cook
So forget her.
My old farm truck
Old 10-21-2007, 04:26 PM   #8
bad6772
Official Site Guitar Shredder
bad6772's Avatar
looks good, did you have any problems putting those Z71 wheels on? are the centers the same.? and how far do they set in the wheel well.....thanks tony...i have a set of these wheels just laying around and would like to put them on my truck......
bad6772 is offline   Reply With Quote
Old 10-21-2007, 05:06 PM   #9
retodd7711
retodd7711's Avatar
the z71 wheels need spacers to fit. 1 1/4 or 1 1/2 I can't remember. The back spacing is wrong.They won't fit the front bearing cover without them and will rub the rear wheel well without them. I went with a smaller tire (235 70 16) The six lug pattern is the same. I can get more pics if you need 'em
She can't cook
So forget her.
My old farm truck
Old 10-21-2007, 05:16 PM   #10
blukangoo
Neighborhood Pickle Slinger
blukangoo's Avatar
I think Iīm a little late but I thought I would post it any ways.
The first 2 pics are how I got them out.
Put the jack under the a-arm and remove the u-bolts. Lower the Jack and the spring falls out without flying through the shop.
Putting them back in isnīt as easy but you have to do it in a certain order.
Put the a-arm back in and reinstall the u-bolts. Connect the bottom balljoint and tighten it.
Put packing straps around the jack and frame like in the last picture and raise the jack til you can tighten the upper ball joint.
The straps keep the truck from raising up.
Make sure the bottom edges of the jack are smooth. You donīt want them to cut the straps when lifting.
My C10 Diary
Our cars:
1966 Chevrolet Chevelle 396 - TH350
1968 Chevrolet C10/CST 327 TH400/375
1969 Corvette Stingray 350 - Muncie Manual Trans
1969 Chevrolet ElCamino 350 - TH400
1970 Cutlass Supreme Convertible - 350 Rocket - TH350
1973 Camaro LT - New Engine Done - TH350
1973 Corvette Convertible 454 - TH400
blukangoo is offline   Reply With Quote
Old 10-21-2007, 08:12 PM   #11
2bits
2bits's Avatar
I never thought to disconnect the Ubolts! very interesting. Seems like you wouldn't need to raise the truck up as much this way which is good. One thing, In your putting it back together step, you say to connect the bottom ball joint but in your take it out steps you didn't say to disconnect it and pic looks like it is still together. Was that just a typo, or? Looks like you took everything apart so that would make sense, but I wonder if it could be done this way without removing any of the ball joint connections? hmm
Thanks for the photos!
_______________
Thomas
'78 Silverado
'74 Monte Carlo
'47 Teardrop Trailer
East Texas Classics Local Club
2bits is offline   Reply With Quote
Old 10-21-2007, 08:29 PM   #12
Andy4639
Old member
Andy4639's Avatar
You have to take one or the other off (BALL JOINTS) to get the A-arms apart. You have to seperate them to have the lower A-arm to seperate from the top. You can take only one ball joint apart though.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 10-21-2007, 09:13 PM   #13
Boog
laying low
Boog's Avatar
It can be done easier. First off it is a lot easier replacing the springs while the front cap and engine are still in the truck. The weight of the vehicle works for you while jacking the spring and control arm back into place. I only did one side at a time leaving the opposite side tire on the floor. Place a jack stand securely under the frame high enough to lower the control arm almost straight down with the floor jack under it. Some use spring compressors, I never did. As blukangoo said reattaching the ubolts while under pressure on the jack will be difficult.
I removed the springs from a Trans AM front subframe while out from under the car. Once!
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 10-22-2007, 11:04 AM   #14
TotalChevy1
TotalChevy1's Avatar
Jack the truck up and use a floor jack to lower the arm via the ball joint. Just did mine last weekeend and it took me and my son about 45 minuntes to do both. Just lower the jack slowly and they just fall out and make sure you have someone keep the spring in place and you jack it back up.
1972 c-20, 350/350, dana 60 w/456 gears(no Posi)
TotalChevy1 is offline   Reply With Quote
Old 10-22-2007, 05:02 PM   #15
blukangoo
blukangoo's Avatar
Yes, the weight of the engine still in the truck helps alot. I did it without the engine. That is why I needed the straps to put them back in.
I guess I have to clear something up here.
To take the springs out I put the jack under the A arm, removed the u bolts and lowered the jack and the spring fell out. The ball joints stayed together.
To put them back in, I put the a arms back in and reinstalled the u bolts. Then I connected the lower ball joint, put the spring in and raised the a arm with the jack. I raised it enough to get the upper ball joint connected. Done.
My C10 Diary
Our cars:
Old 10-25-2007, 01:24 AM   #16
72BLUZ
72BLUZ's Avatar
what he said is how we do it. put it on stands. use the floor jack under the aframe and lower it slowly. works evertime
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 10-25-2007, 02:40 AM   #17
powerbench
powerbench's Avatar
i have had the unfortunate chance of having the spring compressor slip....stuck my hand in to pull out the coil...had a jack under the control arm......didn't pop out ,but did spring apart with my fingers in the coil.....hit so hard i didn't feel it at first....then flipped my hand over popped the skin on my finger like a zit ...fractured the bone...hurt like a bugger.....cheap spring compressor
powerbench is offline   Reply With Quote
Old 10-25-2007, 02:42 AM   #18
70short
Talking Re: front spring removal...Dangerous??
I just did mine A week ago Jack Stands and floor jack. piece of cake!
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 10-25-2007, 06:08 AM   #19
blukangoo
blukangoo's Avatar
Ouch!
Thatīs a good story for the people that want to use spring compressors.
You donīt need them!
My C10 Diary
Our cars:
Old 10-25-2007, 06:19 AM   #20
retodd7711
retodd7711's Avatar
I think the reason my rear bumper only dropped 2" is I am still using the stock shocks. I'll install the shorter shocks and re-measure. do you think the stock (new) shocks are holding me up? .
She can't cook
So forget her.
My old farm truck
Old 10-25-2007, 06:34 AM   #21
dznucks
dznucks's Avatar
i got the same story as Powerbench. if you buy or rent the compressor make sure it doesn't slip.
dznucks is offline   Reply With Quote
Old 10-25-2007, 07:31 AM   #22
space
This thread couldn't have come at a better time. I'm replacing my front springs this weekend so the pics definitely help. I didn't even realize they weren't bolted in. That was a hospital trip waiting to happen.
space is offline   Reply With Quote
Old 10-25-2007, 02:58 PM   #23
Luvlegs
Luvlegs's Avatar
Space Cowboy - for a 102 year old, it's pretty cool you are still wrenching. Feb 1st, 1905 right? hahahahaha
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 10-25-2007, 03:08 PM   #24
Jim_PA
Shocks control movement, they don't lift or lower anything. Unless they are WAYYYYYYY too short or long.
Jim_PA is offline   Reply With Quote
Old 10-25-2007, 03:17 PM   #25
Joe67
67 is sold
From time to time this discussion comes up. IMO why would you take any chances?
Rent a good spring compressor and do it right - you won't be disappointed
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
