Old 12-21-2007, 12:04 PM   #1
smoky02
Location: Sunny, Florida, some might call it South Alabama
700R4 lock-up in 68
How did ya'll hook up your lock mechanism in your tranny without having the proper wiring harness?
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 12-21-2007, 12:12 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: 700R4 lock-up in 68
http://bowtieoverdrives.com/index.shtml
I used the TV made EZ cable and their TC lock-up kit. A little over 1 year and over 5K miles later my tranny still shifts great.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-21-2007, 12:53 PM   #3
Ackattack
Ackattack's Avatar
I use the TPI computer to control my lock up.
But, if you look at the wiring diagrams and do a little reseach you should be able to hook up your own lockup switch yourself. If I remember right, its a 5V signal to the tranny. you could just wire it up so that on the highway you flip the switch and it locks up, otherwise run it unlocked. But it wouldn't really be integrated and as convienent.
Ackattack is offline   Reply With Quote
Old 12-21-2007, 12:57 PM   #4
60ratrod
yes, i do
60ratrod's Avatar
what is the pros and cons about running locked and unlocked trans??
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 12-21-2007, 01:05 PM   #5
Andy4639
Old member
Andy4639's Avatar
I bought mine from B&M. I have a toggle switch on the dash to lock or unlock it. If you run it in unlock bassicly is for towing or slower speed's...45MPH or less. Once out on the road and speed over 55MPH lock it in and get the best milage out of your truck.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-21-2007, 01:34 PM   #6
grancuda
grancuda's Avatar
A buddy of mine who runs a tranny shop just puts it on a dimmer switch a little higher up than the stock dimmer and uses that for the lockup
grancuda is offline   Reply With Quote
Old 12-21-2007, 02:21 PM   #7
nightmare
nightmare's Avatar
I did this in my '84 Camaro when I took out the computer. All that I did was run an ignition only power wire to the tranny. All GM parts, using the specified p/n's. It works great, and only locks up in 4th gear.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 12-21-2007, 02:33 PM   #8
cparman
sharp as a marble
I did this in a 67 chevelle. Here goes. the 4 wire connector in the trans is lettered a,b,c,d. The purple wire in the connector you get at the local boneyard is " A"
I ran "A" to a toggle switch, and THEN thru a 4 pin brake light switch out of a 78 corvette with cruise. the tcc lock up was wired thru the cruise " on off " part of the brake light switch.
SO if you were cruising slowly and did not want the TCC to lock up, TURN THE TOGGLE SWITCH OFF. If you are cruising on 45-55 + TURN THE SWITCH ON.
this way you have the best of everything. TCC lock up when you want it.
I intend to do this to my NEW 69 chevy short bed soon.
cparman is offline   Reply With Quote
Old 12-21-2007, 05:37 PM   #9
VetteVet
Msgt USAF Ret
VetteVet's Avatar
here's a wiring diagram of a lockup. If you have a trans older than 85 it will burn up if you don't run it in lockup.
http://www.smokemup.com/tech/700r4.php
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-21-2007, 07:18 PM   #10
71Chevy4-speed
Speed Limit = Floorboard
71Chevy4-speed's Avatar
locked converter helps keep trans temp down, plus it will let you run a stall thats higher than your normal highway rpm.
1971 C20 350, 4-speed - Sold.
1985 K10 350, Built 700r4, Edel 1406, Performer intake, MSD Ign, Hooker Comps, Silverstars, Piaa drivers, LED tails, Toyo A/T 31's, Eaton Posi, the project.
"Build for torque, horsepower will follow"
71Chevy4-speed is offline   Reply With Quote
Old 12-21-2007, 08:46 PM   #11
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
When I had the 700R4 rebuilt for the second time, I had the guy run mine hydraulically. It just goes into lockup at 35mph, all the time. I don't know how its done, but thats what he said he did. Prior to that, I ran it like cparman had his, just hot all the time. May have been why I had to rebuild the tranny more than once...
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 12-22-2007, 01:52 AM   #12
smoky02
Thank ya'll for all the inputs...and guys that are using the toggle switch...do you ever get annoyed or wish it was automatic? And using a dimmer switch is a good idea.
Old 12-22-2007, 02:31 AM   #13
70GMCer
70GMCer's Avatar
Use this....works great......might consider putting it into the FAQ to help others
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 12-22-2007, 09:00 AM   #14
BP68
BP68's Avatar
I got a B&M lockup kit from Jeg's that goes in line with the speedo cable and has a little box with a dimmer style knob that allows you to adjust at what speed/point the lockup comes on.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 12-22-2007, 10:04 AM   #15
smoky02
Oh now that's cool...
Old 12-22-2007, 10:12 AM   #16
38chevyhotrod
38chevyhotrod's Avatar
i have a 96 pickup with a 04l60e trans, this trans doesn't lock up until the oil reaches a certain temperature. Why is that and why isn't it mentioned anywhere when converting to a 700r4 with a lockup system.
Anybody can restore a classic, takes a man to cut one up.....
http://www.arnoldscustoms.com
38chevyhotrod is offline   Reply With Quote
Old 12-23-2007, 02:21 AM   #17
70GMCer
70GMCer's Avatar
Never heard that one before. Guess it's possible with the newer trans though.
1997 GMC Sierra Ext
1965 Mustang
Old 12-23-2007, 02:29 AM   #18
nightmare
nightmare's Avatar
with the 4L60's past '92, i think, the shift points are controlled by the computer. whereas before that time it was controlled hydraulically. it's probably attributed to that
we're mainly talking about putting a non computerized 700R4 into these trucks.
Mike
67-72 FAQ
Old 12-23-2007, 09:22 AM   #19
38chevyhotrod
Ah of course, I could have thought of that by my self.
But it could be possible to put a an adjustable temp switch in the circuit, if it would be better.
