Old 12-28-2007, 10:51 AM   #1
soba_03
soba_03's Avatar
235 & Hei?
Ok I see many HEI distributors out there for every I6 chevy made, except 235. Is there something That I need to be aware of before buying HEI distributor and trying to drop it? Please offer a little insight..
Thanks.....
soba_03 is offline   Reply With Quote
Old 12-28-2007, 11:12 AM   #2
283 Man
283 Man's Avatar
Re: 235 & Hei?
Ithink any small block hei v-8 would work on 235.
283 Man is offline   Reply With Quote
Old 12-28-2007, 11:13 AM   #3
283 Man
283 Man's Avatar
Re: 235 & Hei?
nice burb you have!!!
Old 12-28-2007, 12:09 PM   #4
slepysal
slepysal's Avatar
Re: 235 & Hei?
I ran a pertronix in my old 235, and am using it in my 250
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 12-28-2007, 12:29 PM   #5
jchav62
1962 C-10
jchav62's Avatar
Re: 235 & Hei?
I believe HEI's are offered for the newer sixes, 194, 230, 250, and 292, but for the older 216's and 235's, you may have to go with slepysal's suggestion...Petronix...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 12-28-2007, 03:05 PM   #6
soba_03
soba_03's Avatar
Talking Re: 235 & Hei?
Ok after a few hours of research I've figured it out. The oil pump drive is different, the closest thing to what I need would be 250 st8 6 HEI. Even with this it requires some slight modification. It would seem that it's about 3/16 to short to fully engage the oil pump drive. So the 250 HEI has to have the mount boss removed and a camp installed about 3/16 to 1/4 in further up the shaft. this ensures full oil pump engagement and also full engagement of the camshaft gear.....
Thanks for your help......
Old 12-29-2007, 08:47 PM   #7
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: 235 & Hei?
Here's what I consider to be the best way to rework a HEI dizzy for the 235. http://www.stovebolt.com/techtips/HEI_mini.html
If you don't mind the huge head that GM used on the 250 go here. http://www.stovebolt.com/techtips/hei_conversion.htm
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
