Old 12-30-2007, 07:04 PM   #1
suzq044
Resident Photoshop Nerd
suzq044's Avatar
Brake question
looking over our C10 panel; just wanted to see what the stock brake set-up was under the hood. The brakes are completely gone on the truck, so we are trying to figure out what the problem might be. Can I get some photos of what the master-cylinder should look like stock, with the brake line(s) in there too plz. It would be much appreciated!
PJ - 1966 C10 Panel --
Max˛ - 1964 Jeep Wagoneer Panel-delivery -- Waiting his turn
suzq044 is offline   Reply With Quote
Old 12-30-2007, 07:49 PM   #2
nonos64
Re: Brake question
is it still a single bowl on your break master cyl or double with power
nonos64 is offline   Reply With Quote
Old 12-30-2007, 07:49 PM   #3
suzq044
suzq044's Avatar
Re: Brake question
single bowl.
Old 12-30-2007, 08:24 PM   #4
nonos64
Re: Brake question
break line goes down to a t on drivers side one line goes to drivers side wheel other line to another t on passenger side off that same t on passenger side goes to rear down passengers side frame to another t in the rear then splits off to each side in rear hope that helps try to draw that on a paper it helps
Old 12-30-2007, 08:27 PM   #5
nonos64
Re: Brake question
or if you have an lmc truck catalog it shows it in the break section because you will also need rubber hose sections
Old 12-30-2007, 08:28 PM   #6
suzq044
suzq044's Avatar
Re: Brake question
good to know - thanks!
