Old 03-23-2002, 07:20 PM   #1
Mountain Man
Post Edelbrock 1406 carb Q- manual not that clear
Guys , need some input.
My new Edelbrock 1406 that I put on started right up the first try, but I noticed that the cold (fast idle) was reving up to 3,000 so I shut it down and backed the fast Idle screw all the way out. Now when I start cold, it seems to start right away , and then the rpms drop right off. The only way to keep running is if I manually keep the accelerator down, but it floods until engine gets up to temp, and choke opens up. Then it idles great.
Think that my problem is simply that I do not have that fast idle cam screw turned in enough. How do you set this fast idle screw. Is it suppost to touch the fast idle cam which holds the accelerator out a bit, and then as the choke slowly opens it slides down the came until it does not contact, and then the idle screw that is set takes over?
The manual shows you the locations of the screws but does not explain how to adjust. Am I right about this?
72 C10 Cheyenne Super
Full trim
Factory tach dash
A/C dash
Factory tilt
350 / 350 power train - with Edelbrock components.
Mountain Man is offline   Reply With Quote
Old 03-23-2002, 07:29 PM   #2
slam33
slam33's Avatar
Post
you just need to adjust the electric chock. loosen the the screws that hold the chock cover and adjust it. reset your fast idle. you should be ok
71 basic C-10 350. The only option is the rust.No nothing on it, but thats all about to change. <A HREF="http://www.geocities.com/stevemau/slam33page.html?1004806705410
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
</A>
slam33 is offline   Reply With Quote
