![]() Join Date: Mar 2007
1960 gmc hidden vin
hey guys, im looking at a 60 gmc swb fleetside big back window pickup. im ready to buy the truck, but somewhere along the lines the vin tag was removed, the seller has a title and its current and for a 60 gmc, but i'd like to find a hidden vin to confirm before i shell out any money. anyone know where they are on this year truck?
1978 Chevy C10, 1986 Chevy K20 'Burb, 1970 Chevelle, 1996 K2500 'Burb, 1977 Chevy K10, 1970 Ford F-250, 72 Ford F100 4x4, 1979 Chevy C30, 1982 Chevy C30, 1996 Chevy Dually 4x4 SAS, 1997 Chevy Tahoe, 1991 Ford F-350 cclb dually 4x4 |
yes, i do
Re: 1960 gmc hidden vin
look in the driver's side door jam. it should be in the door jam by the windshield. that's where the vin tag on my 60 is
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
i think he is looking for a hidden vin #, like on the frame somewhere, because the one in the door jamb is missing. Sorry, but I don't know where it is on these models. If I remember correctly, my '59 had it on the driver's frame horn. I might be confusing that with another truck, so I could be wrong.
1976 Chevy 1/2T 2wd SWB ![]() ![]() 327/Saginaw 4spd 3.73:1 LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071 LFSalleeII@gmail.com ![]() |
1961 crewcab
try www.6066gmcguy.org maybe he can help.
resident wrencher
on my 66 there is one on the frame on the passenger side i beleive below the door and one on the frame in the engine bay on the frame on the drive side i believe
thanks for the replies, im going to look at it again this weekend.
1960 GMC Burb
I found this on the 6066 GMC site:
1960-1963 had the tag on the front or "A" post. If the tag is not here, you should see two rivet holes were it was removed or fell off. Not all truck will have the tag in these locations, but most will. Suburbans & Panels may be found on the front or top of the drives door frame, and some may be on the kick panel by the ratings tag. These numbers can also be found stamped on the Top of the left frame rail in two places, on in the engine bay and the other under the cab. They may be covered over in dirt. If no tag is found, the number is also stamped on the TOP of the left frame rail, in the engine bay and also under the cab. The number under the cab is the hardest to see.
1960 GMC Suburban 1/2 ton V-6 2nd generation original owner ![]() 60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban 60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs 2003 Tahoe LT ![]() |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I have the frame from a '60 GMC 4x4 Suburban that has absolutely no numbers on it. I don't know if it just somehow got forgotten at the factory or what. Hopefully the one you're looking at isn't like that one. As posted above the numbers should be on the drivers side frame beside the engine. That is usually the easiest one to find. Good luck.
