02-06-2008, 02:16 AM | #1 |
How to replace spring eye bushings
any one know how i could replace the spring eye bushings in the front of my K10. Is there any particular bushing that i should buy
thanks David
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
02-06-2008, 03:48 AM | #2 |
Everything is work in progress
Re: How to replace spring eye bushings
Take your drill with 3/16" bit. Drill as many holes as you can in the rubber. When it's weak enough you can punch out the rubber. Then take your sawsall or hacksaw and cut the steel bushingdown one side. Tip: cut it where the spring meets it's self to form the circle. That way you have more working room with your blade so you don't cut the spring, and you have room to drive a screwdriver behind the cut so you can fold the cut bushing towards the center and it will fall out.
Then wire bottle brush (like plumbers use) the inside of the spring and spray it the color of your springs and install these http://www.offroaddesign.com/catalog/greasebushings.htm And you'll never have to worry about them again.
Good luck with your truck! How much?! It's just an old truck part!! 49 International on a 80 GMC 3/4ton 4x4 chassis 48 International KB-5 2 ton dump bed 04 Honda CRF "500" 09 Honda CRF450 fuel injected rocket 03 Suzuki hayabusa carbonfiber wheeled monster. 02 Ford diesel stretch van (toy hauler) 01 38' Monaco diesel pusher motorhome Last edited by cobinder; 02-06-2008 at 04:27 AM. |
02-06-2008, 03:49 AM | #3 |
Unbolt spring, and let down slowly. with any luck, you can pry/poke/convince the bushing out. otherwise use a torch and a nose plug. You can find replacements thru vendors on this board, or other places. rubber vs poly, it's all up to you & your checkbook.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
02-06-2008, 12:48 PM | #4 |
I took mine off, torched out the rubber, and then used an air chisel on the outer sleeve. Then replaced with energy suspension urethane bushings....
it's a big pain in the butt... I would just replace the springs if they are shot, unless you like a few hours of nasty work and still spend $40 for bushings...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
02-06-2008, 01:31 PM | #5 |
Hey guys, it might be a silly question but can it be done without completely removing the spring?
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
02-06-2008, 08:36 PM | #6 |
i doubt it would be very easy... the factory bushings are pressed in. The outer sleeve (inside the eye) is very, very stubborn. And I doubt that you want to burn the rubber out while attached to your truck. Once you start it then you are committed to getting it done until you can move the truck.... Might be better to take it to a shop to press them back out.... It's only 8 more nuts to take both springs off all the way.
02-06-2008, 08:56 PM | #7 |
i agreee with msgross, most trucks still have the metal cage thing that keeps the front of the spring from coming down completly, i used a torch and a big hammer and alot of a$$,t o remove em,
1969 rs 1966fastback 1969swbc/10 2006gt 1972swb4x4 |
02-07-2008, 01:11 AM | #8 | |
Good luck with your truck! How much?! It's just an old truck part!! 49 International on a 80 GMC 3/4ton 4x4 chassis 48 International KB-5 2 ton dump bed 04 Honda CRF "500" 09 Honda CRF450 fuel injected rocket 03 Suzuki hayabusa carbonfiber wheeled monster. 02 Ford diesel stretch van (toy hauler) 01 38' Monaco diesel pusher motorhome |
02-07-2008, 11:20 AM | #9 |
I've got removing a sleeve/bushing down to a few minutes a piece!
Take your torch and get the sleeve sizzling hot. The rubber around it will melt and the sleeve will slide out... as slick as.... You'll then be able to get the rubber out almost as easy. However, the rubber will probably catch fire and will, at the minimum, stink horribly. I just pat it with my gloves to extinguish it. The rubber will need to be replaced. It's a touch messy as the rubber turns to an oily mess... permanently. Try not to let the neighbors see you... you might get some dirty looks.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
02-07-2008, 11:37 PM | #10 | |
02-08-2008, 03:38 PM | #11 |
msgross,
agree with you too. I took a sawzall and cut the outer sleeve where the leaf wrapped over to itself. There's a small relief at that spot so that you're not cutting into the leaf itself. Then I pryed the outer sleeve away from the leaf with a flat blade screwdriver and soon enough you'll be able to knock it out with a few light raps from a hammer. Hopefully, there's not much rust holding those pieces together!
02-08-2008, 03:40 PM | #12 |
O.K. .....
maybe a few HARD raps from a hammer!
02-09-2008, 10:39 AM | #13 |
yeah, i needed a bigger hammer too....
04-27-2008, 07:23 AM | #14 |
i usually use a sharp punch to cut the inner sleeve and a big hammer hitting down on it, AFTER I TORCH THEM OUT AND LET THEM BURN , im going to attempt to press mine out at work...70 ton press,
1980 stepside project, all original, 77,000KM, 292 / 4 speed soon to be dropped, and on 295/50 15s out back 1981 long box, 9 inch all susp, 38s, 1 ton 4:56. awaiting trans/tcase and work! Last edited by GMCStepside; 04-27-2008 at 07:24 AM. |
