Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-10-2008, 08:51 AM   #1
joehalford01
joehalford01's Avatar
strength of airbag set-up
Hi guys,
I've been working on my 63 longbed for a while and I'm at a make or break point. I've gone a long with the whole cruiser longbed with bags thing idea but it's not really what i'm interested in. I'd like to make a screamer out of it but i don't think a long bed is much of a hot rod. I'm considering bob-tailing it to lighten it up and give it a more hot rod look. I've already purchased the bags and a 10" step notch bridge kit. How will the bags hold up in a high horsepower application? I currently have a 327 that is a bit tired and will get rebuilt to run 6000-6500rpm passes. Let me know what you think.
joehalford01 is offline   Reply With Quote
Old 02-10-2008, 10:29 AM   #2
GMC70c20
Re: strength of airbag set-up
the air bags wouldn't be the weak link of your rear, it would be the control arms. There's some guys that run bags on there drag truck so they can get it down in the weeds when your at the track. If your gonna run a 327 and only rev it to 6500rpm you should be fine with the stock control arms or stock leafs. You can re-place the coils with the bags and adjust the rear for the right pinion angle and run it that way. Or if you want to save some more weight I've seen guys make there own control arms out of mild steel square tube. Or if you wanna get real crazy stick a 4 link under it with the bags and that would be perfect for racing. If you want your truck to hook at the track I would not use them in the front
GMC70c20 is offline   Reply With Quote
Old 02-10-2008, 03:11 PM   #3
joehalford01
that gives me somewhere to start. I plan on shortening my stock trailing arms and boxing them up for strength so i should be good there. thanks
Old 02-11-2008, 10:34 AM   #4
GMC70c20
well if your gonna be cutting them up anyway you may as well make new ones, I think the stock ones are cast Iron which is a mother f$$$er to weld and have it not crack.
Old 02-13-2008, 12:51 AM   #5
djracer
djracer's Avatar
don't cut the trailing arm! My truck has been in the 1.20's in sixty foot and is capable of a high 8 second run and it has trailing arms!
Long bed and short bed arms are the same!
If you were not on the other side of the world i'd give you a short bed frame.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 02-13-2008, 03:01 PM   #6
GMC70c20
wouldn't a tubular control arms be lighter therefore better for the track? Wouldn't making a tubular control arm be not real hard to do?
1970 c20 converted to c10 sleeper
1979 c20 the wood hauler
1991 honda civic daily driver
spray and pray baby
Old 02-13-2008, 03:02 PM   #7
Outlaw72
Hay Team!!
Outlaw72's Avatar
CSS sale a set that appear to be pretty nice.
1972 Chevrolet Cheyenne LWB "Orange and White" 8)
Outlaw72 is offline   Reply With Quote
Old 02-13-2008, 09:25 PM   #8
djracer
djracer's Avatar
they do look pretty sweet!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-14-2008, 02:11 AM   #9
Super73
Super73's Avatar
The only negative thing I can see with a tubular arm is ride quality. The double I C beam ][ allows for flex under a bump situation. That flex will also keep the suspension out of bind easier.
If this is a 1/4 mile truck that doesn't get driven on the street, no problem. Or your not concerned about a rougher ride, no problem.
Super73 is offline   Reply With Quote
