Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 02-14-2008, 03:33 AM   #1
454_72_4X4
454_72_4X4's Avatar
V-8 swap radiator?
Lookin for opinions.
I'll be swappin an 89 TPI305/700r4 into my 98 Sonoma, (hopefully soon...) and was lookin for different options and experiences with radiators.
Lookin at a BeCool radator but it's close to 800 bucks! (2 row auto trans style)
Link;
http://www.naparts.com/ProductDetail.cfm?ProductId=1177
I used one made by Superior radiator for my 87 back in 95? when I did the swap. It was a good quality radiator and cooled good once I built a shroud for it. But it was a copper/brass "forward" mount style, (no AC truck), and this time I'm lookin more along the lines of keeping the AC and using an aluminum rad.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 02-14-2008, 03:58 AM   #2
C.W
Re: V-8 swap radiator?
I have used both the stock 4.3L rad and the mid-late 80's vette rad. An electric two speed fan from a ford taurus helps alot too. They pull an unbelievable amount of air.
86 Burb, 5/7 drop, 18" rims, big stereo, work in progress, as well as daily driver.
86 Short box just starting the build.
86 GMC 1500 2wd, ugly blue farm looking truck with a mild 454... More to come!
98 Cheyenne Ext cab short box 2wd. Driver and maybe future project.
C.W is offline   Reply With Quote
Old 02-14-2008, 05:41 AM   #3
454_72_4X4
454_72_4X4's Avatar
I've heard of the Taurus fan but forgot about it. Thanks for the reminder.
I just can't see a 4.3 rad working out very good. But since I have one of those I'll have to try it out first.
It might work better than I think for a 305.
Should be easy to mount!
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 02-14-2008, 09:41 AM   #4
Tink
Tink's Avatar
Yup, mid-late 80s corvette radiator. I bought one to put in the core support, but may sell it, because I'm going to stick with the 4.3L in the orginal location and run a mechanical fan.
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 02-14-2008, 10:36 AM   #5
454_72_4X4
454_72_4X4's Avatar
I'll probably slide the motor toward the rear and down as much as absolutely possible and put the radiator as close to stock location as possible.
That's the way I did the motor on my 87 but the radiator was positioned in the support. I ran a long waterpump and an 1-1/2 inch spacer for a 19in Flex-a-lite fan. Then I built a shroud out of two Toyota pickup shrouds and some extra sheet metal.
Is the vette rad you guys are referring to the one that's recomended in the JTR manual?
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 02-14-2008, 12:34 PM   #6
C.W
I probly shouldn't admit this but i have never looked at the jtr manual. But i believe it would be the same.
As for the 4.3 rad i used one in my 85 blazer with a 11:1 460hp 406 sbc. It worked awesome, better than the rad i originally had built for it.
Heres a pic of the vette rad in the forward position with the taurus fan as the truck was going together. This was using the trans dapt 4689 mounts and hedman longtubes.
Old 02-14-2008, 01:27 PM   #7
MotorHead Lon
MotorHead Lon's Avatar
The Vette rad is the one refered to in the JTR book. The last time I looked up the price it ran about $195.00. It is supposed to be a bolt in.
88 Chevy C1500, step side, LS swap.
98 Crew Cab Dually, tow rig.
03 Dodge Neon. ECTA Ohio Mile record holder.
MotorHead Lon is offline   Reply With Quote
Old 02-14-2008, 02:03 PM   #8
C.W
Its a little shorter height wise than a 4.3 rad. Makes it fit forward in the rad support alot easier.
Old 02-16-2008, 12:08 AM   #9
454_72_4X4
454_72_4X4's Avatar
Not reading the JTR manual isn't anything to be ashamed of. Believe me, they're not "all" they think they are. Don't get me wrong, they do have some good info in there, but some info is totally off the wall.
Your 11:1 406 was probably not a DD though right?
My 87 was my DD. 22mpg at its best with a 328!
Sittin at stoplights every block for what seems like miles in 100+ degree weather is when the temp on my 87 would raise to an uncomfortable level. It climbed as high as 240 a couple times. (Anything above 200 I don't like)
One other time it got "warm" was while cruising through Bear Country USA in SD. The wife, me, and an 80lb Rottweiler in the cab, (with the windows up), putting through a croud of black bears! Hahaha
I want AC next time! LOL
I won't be using kit motor mounts. Seems like all of them, (that I've seen anyway), wanna sit the motor way high and to far forward. And on top of that most of 'em wanna use 2.8 mounts!
I used normal ol clamshell small block mounts and redrilled the holes in the clamshells to lower the motor as much as possible. I still had room under the oil pan, used a HD starter, and 168 tooth flywheel. (Which, BTW, JTR says can't be done). The waterpump shaft was almost dead center in the radiator.
After driving it a few years, I tried a set of Hedman shorty headers. The ones that wrap around the steering shaft. My motor sat way to low and to far back for the Hedmans to even come close to workin.
This time I'm shootin for an AC truck so the radiator will have to be in the stock location. Or real close to it. I might be able to "fudge" it forward a little though.
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 02-16-2008, 12:10 AM   #10
454_72_4X4
454_72_4X4's Avatar
How "thick" is that Taurus fan/shroud?
I just found this on Ebay;
http://cgi.ebay.com/ebaymotors/S10-V...23100085QQrdZ1
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 03-21-2008, 06:39 PM   #11
Slammed70
Slammed70's Avatar
'Vette radiator, mounted IN the core support, using dual fans from uh....I wanna say Fleetwood or Eldorado, which ever one had the Northstar. Wire them both to kick on around 170, cut the center section(you know, the part that holds the hood latch)out of the core support and notch it, get some angle iron and make some brackets to hold the AC condensor IN the new notched area, mount two of the biggest pushers on it you can find. And you can have AC and sit at stop lights.
Oh, and cermic coated headers are a godsend too.
ultra rare corvette option package
Slammed70 is offline   Reply With Quote
Old 03-21-2008, 07:04 PM   #12
Slammed70
Slammed70's Avatar
Here are those fans I was talking about...
Old 03-21-2008, 07:40 PM   #13
454_72_4X4
454_72_4X4's Avatar
Ya sayin 4 fans?
(using dual fans from uh....I wanna say Fleetwood or Eldorado, and mount two of the biggest pushers on it you can find)
Forward clearance probably won't be a problem. The motor will get "pushed" back as far as humanly possible. (No "kit" mounts)
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 03-22-2008, 06:43 AM   #14
Slammed70
Slammed70's Avatar
Originally Posted by 454_72_4X4 View Post
Ya sayin 4 fans?
dual fans.....two of the biggest pushers
Thats 1-2-3....4? Yep four fans I said.
Keep in mind this is for a daily...and I mean snow, rain, 110+ degree days, sitting at red lights with the AC on kind of daily. run that set up and you shouldnt have a problem running warm. And dont run a 160 'stat, run a 180. And if you use the tranny cooler in the radiator, put in inline cooler. The ones from Jegs/Summit for $30-60 that mount on a fram[e] rail work best. And metal lines, they're smaller, dont leak, and they will dissapate heat quicker than rubber.
Last edited by Slammed70; 03-22-2008 at 06:44 AM. Reason: I spelled frame wrong...
Old 03-22-2008, 08:06 AM   #15
454_72_4X4
454_72_4X4's Avatar
Hahaha, well that should do it alright!
I ran a 160 stat during the summer on my last truck and would do it on this one too if it was gonna be built and carbed. This one will be a stone stock TPI 305 and I'll probably use a 170 stat.
It'll have a B&M trans cooler mounted in front of the radiator/ ac condensor somewhere probably. It'll be all hardline with maybe a little rubber at the cooler in/out.
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
