escalade conversion
any body done it here ????got 2004 siverado that was hit in the nose wondering how well the escalade front sheetmetal fits if it does.and who sells kit
thks for any help |
![]() Join Date: May 2007
Re: escalade conversion
I have not done it personally, but the design of the vehicles are the same and will work. I believe stylin concepts sells these kits if I remember right. As of the fitment of the parts it would be worth making sure u use as much genuine GM parts u can. GM always going to cost more but fit better than after market.
i got a 01 hit in front and i was planning this conversion but escalade fenders have a plastic panel that fits over the bottom of the fender so the fender at the bottom has a differt conture but i have heard of people cutting there stock fenders to make a piece to weld to the caddi fender and i have heard you will need to extend wiring harnesses to reach the longer caddi front clip
another option would be to add the plactic trim to your doors and maybe the bed also but it will all work with a little work ps-i just went with the stock clip for the simplicity
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_- 1972 K10 4"lift 33"tires (soon to be bigger and better) 2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's |
i seen one the other day, it was a step side and didn't look right, the front was all square and the back was all round.
