Old 03-23-2002, 12:34 PM   #1
DINS 1
DINS 1's Avatar
Post Drilling six lug pattern in a brake rotor
Has any one drilled a 5 lug rotor for the six lug bolt pattern? I have seen a lot of rear axles drilled for different bolt patterns.
72 3/4 ton 4x4 suburban
71 1/2 ton 4x4 suburban
69 1/2 ton 2wd suburban
79 Camaro RS black & white
92 GMC suburban 4x4
All in Webster City, IA
Wade
"DURAMAX BURB" Burb on 2004 chevy 2500HD 4x4 Duramax chassis Long term project
2004 2500HD 4x4 crew cab GMC Duramax 4" lift 35's
79 RS Camaro
DINS 1 is offline   Reply With Quote
Old 03-23-2002, 01:05 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
If you have 6 lug rims your wanting to keep, you can get 6 lug rotors from GMC Paul.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
Need to pick up the one ton Longhorn with a PONTIAC 350/350soon.
Thanks every one!
Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 03-23-2002, 01:59 PM   #3
Fast68Chevy
Fast68Chevy's Avatar
Post
but if you wante dto do it then you oculd use a 4x4 rotor or 6 lug drum for holes pattern and weld up the 5 holes and grind smoooth and then dril 6 holes
can be done if you have the welder and grinder
-71/C-10(thx teeitup and crews!)350 4+4/CH465(thx 71Chev, GMCPaul, and CPNE)longfleet bed(thnx meathead95)!still building it-
-'84 Z28(Z28) 1G1AP87GXEL100000 with H.O. 305/4bbl/190net/hp(L69) 3.73 rear(GT4/YC4) 700R4(MD8-MXO) & other goodies
-79 G20 pass van, 350/th350/10bolt,
paint is overrated
Randy- Lincoln, IL
r68c30@hotmail.com
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
Old 03-23-2002, 09:57 PM   #4
Don Smith
Post
Don't do it, you won't be satisfied. I had a machine shop do mine, cost 80.00. Never used them. I purchased new rotors from Classic Performance Products.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
