Old 03-24-2008, 07:44 PM   #1
mattman11174
Converting 72 Suburban to a Duramax
Can any one give me some sites or info on converting to a duramax
mattman11174 is offline   Reply With Quote
Old 03-26-2008, 05:17 AM   #2
Angelo
Re: Converting 72 Suburban to a Duramax
Hey mattman11174 you want to put a diesel motor in your suburban just like me, but i think its easier and cheapper to go with a 6.5 Turbo diesel. I want to put the diesel motor in my 72 suburban so i can get better gas milage. If anyone has a build thread can you post it, and the amount of money spent for the motor swap.Thank You
Angelo is offline   Reply With Quote
Old 03-27-2008, 02:15 AM   #3
Frizzle Fry
Frizzle Fry's Avatar
saw diesel at over 4$/gal today...
Frizzle Fry is offline   Reply With Quote
Old 03-27-2008, 06:18 AM   #4
sweet70beast
sweet70beast's Avatar
I have thot alot about puting a duramax in my sub too, but, it makes me wonder if the money spent on the conversion and the higher fuel prices(80cents a gallon )are actually worth the savings. In other words how long would it take to recoup the cost of the conversion and the higher fuel to actually start seeing money savings.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 03-27-2008, 07:30 AM   #5
salvageit
If the gas mileage would not be worth it the power would be. Have any of you drove a duramax with an edge chip? WOW! I really want to do this to my 72 as well. I would not go with the 6.5 just for the fact that the duramax is capable of so much more and the 6.5 does not have all the after market options like the duramax does. If you were able to find a complete motor, tranny, harness and ECU, I dont think the swap would be that bad. I have done a lot of searching and have found nothing so far on this swap.
salvageit is offline   Reply With Quote
Old 03-27-2008, 09:56 AM   #6
race-rodz
5.9 cummins, should be plenty of power for a burban, and in stock trim... 20+ MPG. goin rate in my area is around $1300 for the engine, another grand will get you a OD dodge trans, or the adaptor to run a chevy trans.
and the idea with building an oil burner, isnt to pay $4/gal for pump diesel, but to have the option of running "green" fuel... which even if you buy brand new stuff...works out to about $2/gal of coarse the green fuel is for off-road use only if you fallow the rules.
race-rodz is offline   Reply With Quote
Old 03-28-2008, 07:46 AM   #7
turbohacker
PISS POOR
turbohacker's Avatar
Ive been very interested in putting either a duramax (to keep true to the chevy name) or a 12v cummins in my 67 lwb. I am very interested in where you can find a 5.9 cummins for only $1300. This would greatly benifiet me as I run biodeisel. (about 80 cents a gallon for me to produce it myself) I bilive that at that price for a motor it would pay for itself rather quickly.
Thanks -Nick
Slammed 67 long bed with vette suspention build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=291149
turbohacker is offline   Reply With Quote
Old 03-29-2008, 07:29 AM   #8
DINS 1
DINS 1's Avatar
I am in the middle of putting a burb on top of a 2004 durmax 4x4 chassis. you need a crew cab short box or a ext cab long box chassis to have enough frame for the tail of the burb. then move the rear axle forward to get the wheel base. next build all of the body mounts to fit the wider frame. I am just getting to the fitting of the body on the frame. nothing about this project is easy, but the durmax will be fun when finished
Wade
"DURAMAX BURB" Burb on 2004 chevy 2500HD 4x4 Duramax chassis Long term project
2004 2500HD 4x4 crew cab GMC Duramax 4" lift 35's
79 RS Camaro
DINS 1 is offline   Reply With Quote
Old 03-29-2008, 05:57 PM   #9
Chevy454
DINS: got any pictures?
'72 Super Custom Suburban - 402/400, original bucket seats, 3rd seat, rear air, tilt
A few Yenko cars
Interested in COPOs, Yenkos or other dealer built muscle cars then go here:www.yenko.net
Chevy454 is offline   Reply With Quote
Old 04-16-2008, 02:42 AM   #10
Bowtie7ty
I think a cummins swap would be the best wasy to go,a five speed would go good with it sinse a surbabans are pretty chunky and cummins automatics are known for goin out. My buddys have built 5.9s that still get about 18-22 miles a gallon . You can pick them up for decent prices too , i found a couple out of 1st genertions with manual pumps with 160000 miles and less for around $1800.
Bowtie7ty is offline   Reply With Quote
