Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-14-2008, 11:18 PM   #1
1970chevy
New 515 bbc
Just start up my 515 bbc would any one know what the timing should be at
The motor has 12to1 solid cam rec port dart cnc heads 1050 holley domanitor two stags of nos 250 on fist shot and 150 on sec shot for tranny its a th400 with a break 4500 stall rear end is dana 60 513 gears and 33x18.5 tires i hope this helps
thanks
1970chevy is offline   Reply With Quote
Old 04-14-2008, 11:38 PM   #2
bigjimzlll
bigjimzlll's Avatar
Re: New 515 bbc
What fuel? 36-38 degrees would be a good starting point
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 04-15-2008, 03:51 AM   #3
1970chevy
Re: New 515 bbc
i am runing vp 110
Old 04-15-2008, 02:43 PM   #4
djracer
djracer's Avatar
Re: New 515 bbc
don't spray it with 110. I would say a minimum of 114 on the spray.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 04-16-2008, 05:18 AM   #5
1970chevy
Re: New 515 bbc
thanks what temp should it run at when i was breaking it in it was running 210. after it was broke in it was running 190 to 200 at a idle i have a 4 core rad and i think its 2500 cfm fan
Old 04-16-2008, 05:22 AM   #6
djracer
djracer's Avatar
Re: New 515 bbc
that doesn't sound bad. If you want to lose some weight on the nose I can recommend and awesome custom aluminum radiator company!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-16-2008, 05:26 AM   #7
1970chevy
Re: New 515 bbc
sure i would like to put a aluminum rad
Old 04-16-2008, 05:28 AM   #8
bigjimzlll
bigjimzlll's Avatar
Re: New 515 bbc
Doug Herbert just sent me a flyer...they are selling Griffin Radiators for 159.95 your choice of size
Anderson,CA
Old 04-16-2008, 05:57 AM   #9
djracer
djracer's Avatar
Re: New 515 bbc
http://www.fsrproducts.com/
These guys are the bomb! they built me a custom two pass radiator shipped to my door for 278.00!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-16-2008, 05:45 PM   #10
Alex1
Alex1's Avatar
Re: New 515 bbc
"its 2500 cfm fan"
Personally I prefer a fan (or fans) with 4000 + cfm with shroud. But since this is a race only deal...
Alex1 is offline   Reply With Quote
Old 04-19-2008, 01:12 AM   #11
prostreet1967
prostreet1967's Avatar
Re: New 515 bbc
any pics?
prostreet1967 is offline   Reply With Quote
