Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-18-2008, 11:38 AM   #1
GMC70c20
ls 376/515
I am looking at engine options for my c10 and was thinking about a ls crate engine. I was lookin at the 375 cu in 515hp all aluminum model. I feel kinnda ify about that engine because of the block, how much power can the aluminum blocks handle before they warp or brake? and how long (assuming I dont beat the hell out of it) would this engine last? I listed the specs of the engine below
Part number:
19171225
Balanced:
Internal
Block (P/N 12584727):
Cast Aluminum with 6-bolt, cross-bolted main caps
Bore x Stroke (in):
4.06 x 3.62 (103.25 x 92mm)
Camshaft duration (@.050 in):
226 degree intake / 236 degree exhaust
Camshaft type (P/N 12480110):
Hydraulic rolller
Compression ratio:
10.7:1
Connecting rods (P/N 12617570):
Powdered metal
Crankshaft (P/N 12597569):
Nodular Iron
Cylinder heads (P/N 12598594):
LS3 rectangle port; as cast with 68cc chambers
Displacement (cu in):
376 cu in (6.2L)
Engine type:
LS Series Gen IV small-block V8
Pistons (P/N 19165089):
Hypereutectic aluminum
Maximum recommended RPM:
6600
Recommended fuel:
92 octane
Reluctor wheel:
58x
Rocker arm ratio:
1.7:1
Rocker arms (P/N 10214664 exh):
Investment cast, roller trunnion
Rocker arms (P/N 12569167 int):
Valve lift (in):
.525" intake / .525" exhaust
Valve size (in):
2.16 int / 1.59 exhaust
1970 c20 converted to c10 sleeper
1979 c20 the wood hauler
1991 honda civic daily driver
spray and pray baby
GMC70c20 is offline   Reply With Quote
Old 04-18-2008, 04:30 PM   #2
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: ls 376/515
You're a long ways away from having to worry about the block failing. There's guys running 800+rwhp on stock ls blocks. The cam will be the limiting factor in that package, it's barely using the head flow. The LS3 heads have a TON of potential and have as-cast flow numbers in BBC territory......throw a .650" lift cam in there and you're talking 600+hp easy. If you've got any lsx related questions I'd be happy to help.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 04-18-2008, 09:00 PM   #3
Super73
Super73's Avatar
Re: ls 376/515
Same here.. I have been tuning the LS1's since 2001 (For personal and friends) as well as building LS1 stuff for personal and friends for quite some time.
There are turbo cars going bottom as fast as bottom 8's on stock blocks and cranks. The l92 heads (LS3 heads) are incredible right out of the box (But you need at least a 4.00" bore).
My little 347ci motor with 3 year old factory (ported) LS1 heads is making 430rwhp through a 4L80E (heavy auto). This is with an off the shelf cam. I will be hitting this block/stock crank with a 300hp shot of N20.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 04-18-2008, 09:48 PM   #4
Alex1
Alex1's Avatar
Re: ls 376/515
A top fuel has 8000hp, and it runs an aluminum block.
Like the others have said, the LS series block is more than tough enough for what you want to do.
Alex1 is offline   Reply With Quote
Old 04-24-2008, 04:17 AM   #5
DieselEater
DieselEater's Avatar
Re: ls 376/515
I don't mean to be a wise guy or anything......But, a BBC will make more power, and be cheaper than an all aluminum LS project...Don't be mad at me, just trying to save you a few bucks...
A.........
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
http://profile.myspace.com/index.cfm...ndid=127691959
DieselEater is offline   Reply With Quote
Old 04-24-2008, 04:51 AM   #6
Super73
Super73's Avatar
Re: ls 376/515
Agreed, but a LS1 is A) lighter B) easier to get the most out of it with the laptop tuning and C) has a cool factor people love when you open the hood..
Back to ya, don't get mad.. It's different strokes for different folks..
BTW, I have seen a few 418ci LS1's making over 550-570rwhp. Thats on par with some of the more radical pump gas big blocks I have seen.
