Old 04-22-2008, 03:24 AM   #1
DaddyMack
Wide Eyed User
DaddyMack's Avatar
My Build - Old Blue EyeS
Here are some up date pics:
Just put in the power steering and redid the wiring head to toe...
Also have new gauges, and new wheels and rubber... I will post as I can.. BUT I am not as good as some are at taking step pics
before...
after to come a bit later have to jet out for a while...
1962 Chevy P/U SB Fleetside
350/350
2.5/5 static drop
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723
Final (as final can be ) Pics: http://67-72chevytrucks.com/vboard/s...d.php?t=393441
DaddyMack is offline   Reply With Quote
Old 04-22-2008, 03:28 AM   #2
joe231
joe231's Avatar
Re: My Build - Old Blue EyeS
looking good!!!
CHEVY ONLY
Old 04-22-2008, 04:08 AM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Smile Re: My Build - Old Blue EyeS
Is that the finished gauge panel in the truck?? Looks cool if it is.........are you building a hybrid low-high hump tranny cover? Good looking project.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 04-22-2008, 04:14 AM   #4
joe231
joe231's Avatar
I did a instrument cluster kinda like that on a '65 I had years ago. took out the black panel and polished it with a wire wheel. the writing is on the glass, looked pretty cool, wish i had pics
CHEVY ONLY
Old 04-22-2008, 05:41 AM   #5
Dadsredwagon
Dadsredwagon's Avatar
looks to be lowered , what did you do to lower it?
Dadsredwagon is offline   Reply With Quote
Old 04-22-2008, 07:20 AM   #6
DaddyMack
Wide Eyed User
DaddyMack's Avatar
Here are some of the wiring photos:
and the New panel is this:
All digital from Dakota Digital. They sent wrong color (green) so it goes back (that's why plastic is still on it), and in a week or so I should have the correct color BLUE. Looks very coo1 ! Original dash will be for sale, in classifieds soon.
Wiring turned out to be very easy. Just seprate and do in sections no prob.
The power steering add:
Not bad for a first timer install. Had custom hoses made (measure fifteen times, cut once, lol). Drilled through fender well and used grommets for neater install). You can see the a little bit of the wiring redone in the engine bay, much neater and no odd wires with no beginning and no end...lol
350/350
2.5/5 static drop
Old 04-22-2008, 07:27 AM   #7
DaddyMack
Wide Eyed User
DaddyMack's Avatar
Final pictures...
of power steering, new ididit steering column. I have a new (old) steering wheel coming as well. But it is coming from Japan, so it may be a while...lol. Very cool, something out of the ordinary. After I took this pic, I did take my plasma cutter to the sheet metal where the steering univeral joint comes through the fender well to open it up a bit!
Pics of new wheels and tires....
Truck sits on 2.5 inch drop spindles in front and 5 inch dropped springs in rear. Ford nine inch rear end. 4 wheel power disc brakes. (5 on 5). Wheels are American Racing Torquelite 18x8. Tires are Faulken 452 (LMAO! they are Y speed rated - over 184 mph .. like I need that) 255-45/18. Oh yea.. grill is from a 61 obviously even though its a 62. I like the dual headlights
Steven
350/350
2.5/5 static drop
Old 04-22-2008, 07:34 AM   #8
DaddyMack
Wide Eyed User
DaddyMack's Avatar
It is not, that was the original, the finished panel is digital. It is a low hump I believe (shift was originally on floor I think, although the original column had shift linkage on it as well). Just missing that front piece but it will all be fixed when I do the interior.
2.5 inch dropped spindles in front and 5 inch drop springs in rear. very drivable but a few high - speedbumps get the exhaust a bit.
Next up is major steam clean, then moving the fuel tank to the rear and possibly putting a wood bed in it (has sheets of plywood now, although it makes for easy access )
after that Interior - exterior I like the way it is, although my kids keep telling me to paint it.
Then the engine compartment and air. Air could be sooner than later because I live in vegas!
Steven
350/350
2.5/5 static drop
Old 04-22-2008, 07:37 AM   #9
neto
neto's Avatar
Nice build! The power steering did you have to change the arm on it? On mine I kept it the same but I'm still at the frame build.
neto is offline   Reply With Quote
Old 04-22-2008, 07:49 AM   #10
DaddyMack
Wide Eyed User
DaddyMack's Avatar
Thanks!
Only changed the pitman arm. All other geometry remained the same. I have seen some other installs that go through the frame for the gear box install, where mine is notched. Could be the year, could be my amatuer install..lol.. but it all lined up.
350/350
2.5/5 static drop
Old 04-22-2008, 07:50 AM   #11
joe231
joe231's Avatar
looks very sweet!
CHEVY ONLY
Old 04-22-2008, 07:58 AM   #12
DaddyMack
Wide Eyed User
DaddyMack's Avatar
Originally Posted by joe231 View Post
looks very sweet!
thanks! work in progress that's for sure!
350/350
2.5/5 static drop
Old 04-22-2008, 01:50 PM   #13
truckn'
truckn''s Avatar
looks sweet, who did you purchase your wiring harness through, did it give you alot of trouble?
chevy, it's the american way
truckn' is offline   Reply With Quote
Old 04-23-2008, 07:20 AM   #14
DaddyMack
Wide Eyed User
DaddyMack's Avatar
EZ Wiring and zero problems... really very easy. Everything is marked.
and 25% the cost of most others.... I did see another that might have been worth a few extra bucks, just because of the way some of the circuits are handled and the mounting. Can't remember the brand but it has been mentioned on this site a few times.
350/350
2.5/5 static drop
Old 04-23-2008, 07:46 AM   #15
Iron-Butt
454 club
Iron-Butt's Avatar
good job, new wiring always makes it better
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 04-23-2008, 12:33 PM   #16
truckn'
truckn''s Avatar
cool I bought one from EZ a month ago, hadn't got around to that yet makes me feel more comfortable knowing someone else has used it and it worked out.
Old 04-23-2008, 02:33 PM   #17
DaddyMack
Wide Eyed User
DaddyMack's Avatar
Yup! It was the first time I did anything like that too...!
350/350
2.5/5 static drop
Old 04-23-2008, 03:45 PM   #18
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
NICE,NICE,AND NICE Looks good man!!!!!
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 04-24-2008, 07:46 PM   #19
fercho71
fercho71's Avatar
all i can said its i agree broo sweet truck
Fer
1966 chevy c-20 truck " La Chata " under construccion
fercho71 is offline   Reply With Quote
Old 04-29-2008, 07:09 AM   #20
DaddyMack
Wide Eyed User
DaddyMack's Avatar
Fer
Thanks!
350/350
2.5/5 static drop
Old 04-29-2008, 07:42 AM   #21
protrash64
protrash64's Avatar
Have you gotten the chance to try out the power steering yet? I went to a quick ratio box and have a similar tire/wheel combo.........turns like its on rails!!!!!!
Old 04-29-2008, 07:54 AM   #22
DaddyMack
Wide Eyed User
DaddyMack's Avatar
Oh yaaa.. been driving it around.. we have a Hot Rod nite at a local bar "Hogs and Heifers" tomorrow nite... will be there. In fact drove around to day... what a difference, best thing I did so far!
350/350
2.5/5 static drop
Old 04-29-2008, 08:11 AM   #23
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Looks Sweet man....wheels and tires look'n good man !!!
Good job on the wiring and grommets...I'm a big fan of grommet use !!
I have seen a few car fires due to the lack of them .
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 04-29-2008, 06:03 PM   #24
DaddyMack
Wide Eyed User
DaddyMack's Avatar
Thanks... appreciate that! Especially from someone that does this for a living!!!
I am getting there... I don't have all the resources or knowledge to go any faster.. it probably takes me twice as long to do something as someone that has done all this before, but I love the challenge and learning, that's for sure. My son helps and he is learning and getting ideas for his 64. That one we are taking completely down to the frame and building it back over next two years. This one is my runner and will be updated a bit, as I go.
Steven
350/350
2.5/5 static drop
Old 04-29-2008, 07:40 PM   #25
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Steven
That's the way I did as a kid, and still do on occassion.....you learn from challenges, hands-on, and screws up too.
Keep it up bro !!!
How was the weather there this past weekend ??
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
