Old 05-01-2008, 01:36 PM   #1
mothertrucker424
mothertrucker424's Avatar
add a leaf
can i cut down a full leaf down and bolt a few cut down leafs to my front pack togain more Lift and how much lift will my shocks accept from my 4" lift
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
1972 K10 4"lift 33"tires (soon to be bigger and better)
2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's
mothertrucker424 is offline   Reply With Quote
Old 05-02-2008, 04:10 AM   #2
msgross
msgross's Avatar
Re: add a leaf
how much do you want to gain. an add-a-leaf is nothing more than a shorter leaf bolted on the bottom with a new center pin. It will make it a lot stiffer and your U-bolts might not fit...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 05-03-2008, 01:56 PM   #3
mothertrucker424
Re: add a leaf
i was thinking two inchs worth sorta like a 0 rate but with more lift
Old 05-03-2008, 02:02 PM   #4
msgross
msgross's Avatar
Re: add a leaf
I gained 1.5" from my rancho leaf, 1/2" for the actual metal and one inch or arc but I only had two leafs in the rear to start with... so now I have three
The Garage:
Old 05-03-2008, 05:28 PM   #5
Burt4x4
Burt4x4's Avatar
Re: add a leaf
Messing with the front like that you MUST secure the "add a leafs" to the leafpack & replace the center bolt on your leafpack. If you don't they may be able to spit out = bad bad steering = crash and burn.
Not too may people taking this route so you will be unique
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 05-05-2008, 05:30 PM   #6
mothertrucker424
Re: add a leaf
it would be safe sorta like a block bolted to the spring right??
Old 05-05-2008, 06:49 PM   #7
FormerMember
Re: add a leaf
Yes, but you really can't go too big with blocks. The add-a-leaves typically run the length of the spring, giving them less of a chance to spit out by providing more surface area (tension) for adherence.
Also, remember that u-bolts are one time usage. They "stretch" as they tighten.
FormerMember is offline   Reply With Quote
