Old 05-06-2008, 05:24 PM   #1
67mater
67mater's Avatar
Need pic of shackle angle
I am re building a 67 4x4 with late model HD springs (relocating mounts/shckle flip, etc.). Can someone posts pictures or suggestions for the shackle angle when the eight is off the tires? front and rear. Is it Forward or back of vertical?
THANKS!!!!
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 05-06-2008, 08:48 PM   #2
FormerMember
Re: Need pic of shackle angle
Shackle should be back. I like to see them about ten degrees with all the weight on the rig.
You can see what I did on my frame, where I positioned my shackle hanger, etc, pics are in my sig.
FormerMember is offline   Reply With Quote
Old 05-06-2008, 08:52 PM   #3
67mater
67mater's Avatar
my issue is that I have no weight on right now. I am trying to judge were the shackle to should lie with the tires off the ground.
1967 K10
1967 Camaro
Old 05-06-2008, 08:54 PM   #4
FormerMember
That's really tough to do. Spring rates, weight and all of that will change the shackle angle. I prefer to do them with all the weight on, as it's far more accurate. Caster and pinion angle will also change...
Even if you have to pile on cinder blocks (done it) to guesstimate.
Old 05-06-2008, 08:57 PM   #5
67mater
67mater's Avatar
looks like when you had bare frame in the air you lines the shackle mount to be straight above, correct?. How does that work out once the wieght is on? will that give the 10-20 degrees back angle?
1967 K10
1967 Camaro
Old 05-06-2008, 09:01 PM   #6
FormerMember
It did for me, but I have allot more weight and spring.
Old 05-06-2008, 09:32 PM   #7
cobinder
Everything is work in progress
cobinder's Avatar
67, depends a lot on your leafs. If they have a lot of arch in them they will flatten more when you put weight on them. A flat spring moves less. Also the number of leaves has an effect on how much it flattens out. As grendel said 10 degrees is a good rule of thumb. But you gotta design the spring system as a whole to get the best ride. And after all the location of the shackle is mostly about getting the best ride.
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
Old 05-10-2008, 02:46 AM   #8
msgross
msgross's Avatar
These leafs are K-10 with a add-a-leaf added, so it arched them about 1.5" more with no weight right now... (eye to eye is shorter now) It's a 68 SWB K-10
The front is stock HD springs (3 each) with no weight...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
