Old 05-10-2008, 01:00 AM   #1
BigCarl
My project 69 C20.
I have a small problem with my frame. Well, hopefully its a small problem. I have looked the forums here, but can't seem to find any pics with the same trouble that I have; a few cracks where the shock mounts attach to the cross member. Some one has welded the crack in the passenger side, but there still remains a few more and of course at every rivet.
Here is a pic.
Can this cross member be purchased or am I going to have to do some fab work in welding and bolting?
BigCarl is offline   Reply With Quote
Old 05-10-2008, 04:55 AM   #2
bedsled71
bedsled71's Avatar
Re: My project 69 C20.
i dont think ive seen that crossmember for sale
bedsled71 is offline   Reply With Quote
Old 05-10-2008, 05:19 AM   #3
BigCarl
I haven't seen it for sale either.
Any recommendations?
Bump this for answers.
Old 05-10-2008, 05:44 AM   #4
SanitysBane
Is it just me or does that driveshaft also look to be "custom" made? Might want to check into that as well.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 05-10-2008, 06:04 AM   #5
scotts62
One day...
scotts62's Avatar
Haven't seen any for sale either. I would check around salvage yards or something if you wanted to keep original crossmember, and just grind or torch rivets then bolt new one back it.. or fab a new one..?
Scott
93 crew cab build
Project 62
Old 05-10-2008, 06:29 AM   #6
TimE
Hey Y'all!!
TimE's Avatar
Yup. Salvage yards or the parts board on here.
I have an off topic question about the rearend too. Pardon my ignorance but what kind of rear is that? It appears to be a chunk type and the panhard setup looks exactly like the one on my 64. I thought all 65-up trucks had the panhard bar mount that was part of the housing and were 12 bolts. I am just curious because I actually have a 69 and a 71 and have owned 4/5 others in the past and haven't seen this type setup personally on one.
TimE is offline   Reply With Quote
Old 05-10-2008, 06:42 AM   #7
PBFAB.COM
PBFAB.COM's Avatar
Just pulled one of a truck... PM me if you are interested. (I will have to make sure it didn't get tossed into the "scrap metal pile").
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 05-10-2008, 04:17 PM   #8
BigCarl
As far as I know about the rear end is, its the non-dana. That is it. I am slowly learning this truck as I am going over it. Searching for the stuff I know is wrong and replacing it bit by bit and of course finding new stuff to fix along the way. The project just started about 2 weeks ago when I tore off what remained of the box and removed what remained of the interior. Now its new parts, parts, parts. I can take more pics of it for you if you would like and maybe some one else on the board can help us both out then.
Old 05-10-2008, 05:01 PM   #9
HotRodYJ
HotRodYJ's Avatar
3/4 ton and 1 tons had an Eaton rear axle. The early predesessor to the later 14 Bolt corporate axle.
My opinion if your having trouble locating a new crossmember and don't want to fab a new one, I wouldn't hesitate to grind the cracks then weld them back up. You need to grind them first past the end of the crack to relieve any stress, then weld them back up and it'll be good as new. If you don't grind the crack first, the stress could still be present and the crack may continue and/or return. Odds are they cracked due to some very heavy use at one time in the trucks life.
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
Old 05-10-2008, 10:32 PM   #10
BigCarl
I could only imagine the abuse this took as it was a farm truck used my an old Ukranian. He had even rigged up a home made secondary fuel cell with a faucet-style switch. It was interesting to see.
I am going to try to get a crossmember or 2 from some users on the board here (this is my preferred method), but if I can't, what are your recommendations for welding around the rivets? Just weld them in all together? That is what I think I will have to do.
My fingers are crossed this is the only frame repair I will have to do. Everything else looks fine in that area.
Old 05-13-2008, 01:34 PM   #11
HotRodYJ
HotRodYJ's Avatar
Remove the rivets where you need to, to repair the cracks, then use bolts when your done to replace the rivet.
Old 05-13-2008, 03:57 PM   #12
BigCarl
What I thought, thank you very much. Looks like I am going to be getting another crossmember, so I am going to taking this one out, replacing it with the newer one and repairing this one for a spare.
Thanks a ton from everyone.
Old 07-13-2008, 02:23 PM   #13
BigCarl
I am still looking for a good solid cross member. So, if anyone has one that they are looking to get rid of, it would be greatly appreciated.
Old 07-14-2008, 12:21 AM   #14
Twistedsteel
Twistedsteel's Avatar
I agree looks kinda small to me, 2" pipe?
Twistedsteel is offline   Reply With Quote
