Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-20-2008, 05:27 AM   #1
Restrorob
The One And Only !!!
Restrorob's Avatar
Have A Couple 502 Crate Questions
Hey Guy's,
I just added this truck to my fleet;
http://www.cardomain.com/ride/3076239
Is there a way I can identify which build 502 is in this truck (stamped numbers etc.) in the block ? The man that had the engine installed is no longer with us.
Also, Is this engine built on the 454 platform ? It's been sitting under cover for six years so I want to replace the water pump/all hoses and a few other parts.
Thanks for any guidance.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 05-20-2008, 03:17 PM   #2
djracer
djracer's Avatar
Re: Have A Couple 502 Crate Questions
Try actually posting the pics! I can't view Car domain from work!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 05-20-2008, 03:45 PM   #3
JayG
Formerly ADHDCARGUY
JayG's Avatar
Swet looking truck, Restrorob!
Jay
67CHEVY SWB,355, built 700r, 5/7,9",posi 3.50,REAR BAGS,HOOSIERS, A/C.
54CHEVY - BURB, beginning construction(well, i gotta take it apart first!)
36FORD PU - WAITING
38CHEVY - 2DR SD,CHASSIS FINISHED
46CHEVY - BURB - waiting
JayG is offline   Reply With Quote
Old 05-20-2008, 11:48 PM   #4
Restrorob
Restrorob's Avatar
OOOK;
No pics of the engine yet, The engine compartment needs a detail job but may get started on that this weekend.
Thanks Jay, Always wanted a BB Chevy but never ran across the right one but I think this is it !!!
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 05-21-2008, 12:06 AM   #5
70rs/ss
70rs/ss's Avatar
Close to a 502 can be built out of a 454 stroked and bored (reallllly bored out), but the 502 is based on a block cast with a bigger bore than the 454 blocks. I'd guess there should be a casting number on the rear of the block, like the other GM motors, as well as any stampings on the passengers front pad. Let's see the motor (502 will lookexactly like any other BBC, BTW)
70rs/ss is offline   Reply With Quote
Old 05-21-2008, 01:07 AM   #6
bigjimzlll
bigjimzlll's Avatar
The 502's have a plastic timing cover...the new generation 454's probably do to. If it has a metal cover it is for sure not a 502(they don't make one) or they didn't last year anyways.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 05-21-2008, 03:38 AM   #7
djracer
djracer's Avatar
Sweet lookin truck!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 05-21-2008, 04:21 AM   #8
Restrorob
Restrorob's Avatar
Thanks djracer,
I got this one for more show than go even though it will go.....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 05-21-2008, 10:40 PM   #9
ripdog28
ripdog28's Avatar
One of the easiest ways to find out if it is a real 502 is there is not a mechanical fuel pump mount on the front passanger side of the block like other BBC's.
A 454 .100over and 4.25stroke is a 506. can be done a company www.SpeedOMotive.com makes them.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
