Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 05-24-2008, 06:37 AM   #1
flamingbig10
6.0 powered square
flamingbig10's Avatar
amp question
I looking to add a amp to my truck but I don't know how many watts or if I should get a multi channel or mono, I already have a Kenwood Cd Receiver that puts out out 4 x 45 watts peak and the subs I have are two 10 inch jbl with a 400 watt peak in a ply wood truck boxes, and would also like to add two 6x9s and a two speakers for the dash, also what amp and speaker wire should I use, If this helps I only listen to country music and I want the best sound and base for the buck
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 05-24-2008, 10:57 AM   #2
AceX
>130dB Moderator
AceX's Avatar
Re: amp question
What kiind of budget are you looking at? I know of the PERFECT amp for your application, but it isn't cheap...
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 05-24-2008, 08:53 PM   #3
flamingbig10
6.0 powered square
Re: amp question
My budget is no more than $400 for the amp, speakers and wires
Aaron
Old 08-22-2008, 03:12 PM   #4
djracer
djracer's Avatar
Re: amp question
I would use a 4 channel amp with two channels on all 4 of the highs and the other two channels mono or stereo on the tens depending on the ohm load of the subs. I can help if you want. I have been in the business since 86! ALL RADIO POWER SOUNDS BAD! There is not enough room in the chassis of the radio to put a decent amp!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 09-06-2008, 03:33 PM   #5
orbot
orbot's Avatar
Re: amp question
DOnt kid yourselfe with the peak power rating, go with the RMS rating.
Ide use amp foa all speakers, twice i had trouble with the stereos due to overheating speaker outs.
orbot is offline   Reply With Quote
Old 09-06-2008, 09:56 PM   #6
djracer
djracer's Avatar
Re: amp question
actually all power ratings are bogus so I look at the size of the fuse to determine the power potential.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 09-06-2008, 10:48 PM   #7
flamingbig10
6.0 powered square
Re: amp question
well now I have and amp sony xplod 600 watt 4 channel the one from walmart http://www.walmart.com/catalog/produ...uct_id=9907092
now I need to get speakers and I might get a 2 channel amp I think it a 1000 or 1500 watt and I can also get 2 1000 watt kickers my neighbor might sell them to me for 200 bucks
Aaron
Old 09-09-2008, 01:20 PM   #8
tommyd241
tommyd241's Avatar
Re: amp question
What are the specs on that amp? The Walmart link does not say how many RMS watts/ch, RMS watts bridged, or the lowest stable impedance bridged.
tommyd241 is offline   Reply With Quote
