Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 11-08-2002, 01:34 AM   #1
Ron's68
Ron's68's Avatar
Question P.S. pump pulley?
Has anyone ever removed the pressed on power steering pump pully? How do you do this? Mine is from an 87 truck with a serpintine pully and I need to put on a V-belt pully. I would like some input before I start putting it on the press. Is the allen head on the end of the shaft something that needs to come off first? Thanks.
68 LWB, .040 over 350 with 10:1 pistons, balanced, vortec heads,comp 270H cam, air gap RPM manifold, holley 750, 4.10 posi and gear drive to annoy the neighbors.
Ron's68 is offline   Reply With Quote
Old 11-08-2002, 02:28 AM   #2
Fast68Chevy
Fast68Chevy's Avatar
you need ot go get a pulley puller tool, its special for p/s pump pullies only and even with this tool its a pain in the ^%$#@! to get the pulley off, is easier to do with pump mounted on engine or something stationary.
good luck
Fast68Chevy is offline   Reply With Quote
Old 11-08-2002, 02:34 AM   #3
jostrans68
Jostrans68
jostrans68's Avatar
A little trick I used is with the puller (Avail at Napa) use a hose clamp around the puller clamps to keep them from flexing. Then with air if availl it comes off pretty easy... My .02 Jack
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 11-08-2002, 03:18 AM   #4
Ron's68
Ron's68's Avatar
Thanks for the replies. I'll be trying it this weekend.
