Old 05-07-2002, 08:47 PM   #1
imdarren
imdarren's Avatar
Post What Parts R Needed 4 I6 To 350/350 Upgrade?
I need a list of parts I will need to upgrade from a 292 Inline 6 / 3 Speed to a 350 V8 Turbo 350. Will I need motor mounts, Tranny cross member, etc. etc? Give me an Idea of what parts I will need to start collecting.
Also, does someone make new motor mounts to use instead of the old factory ones. It will probably be a high horsepower(about 400hp) 383 motor with lots of torque.
All this is for a 67 C10 LWB truck.
Thanks! Darren
Darren
Washington State
darrengale67@hotmail.com
1972 GMC C1500 (Bone Stock)
1967 Chevy C10 LWB
Looking for a 72 3/4 Ton 4x4 Cheyenne Super with little or no rust.
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 05-07-2002, 09:41 PM   #2
Randy70C-10
Randy70C-10's Avatar
Post
Yes, motor mounts, motor mount towers, tranny crossmember, and I'd recommend a new radiator (at least a 3 core). You'll need another driveshaft too, I can't remember if it will be longer or shorter though.
Yeah, that's right. My name is Randy too!
WWW.Randysrods.freeservers.com
1970 Chevy C-10 shortstep
30 Ford Model A Coupe 4 inch chop, 350, GMC 671 blower-Hell yeah it's fast!
87 Harley Sportster(couldnt get a 350 to fit)
Self Propelled Lawn Mower
Built in USA!!!!
Virginia Beach, VA.
Randy70C-10 is offline   Reply With Quote
Old 05-07-2002, 11:59 PM   #3
imdarren
imdarren's Avatar
Post
So, you use V8 Towers, and then can I upgrade to new (is it polyurathane) motor mounts? I have heard people say to use brand new (better quality) motor mounts. Anyone know anything about that? Darren
Darren
Washington State
1967 Chevy C10 LWB
Washington State
Old 05-08-2002, 12:18 AM   #4
frost89434
frost89434's Avatar
Post
I just did that swap a month ago. The motor mount towers were the same I just had to change the motor mount. You will need the transmission crossmember. And I went to a three core radiator. Also what I did was I got a shorttail shaft 350 turbo and put the engine in the I6 postion so I wouldn't have to lengthen the driveline. As a fact I didn't have to do anything to the driveline. I hope this helps. like I said I just did this a month ago. If you have any other questions you can e-mail me.
67 3/4 ton progect
68 chevy swb stepside
Sparks NV
68 short fleet with 71 front clip 2wd jaguar blue
99 chevy ext cab shrtbed z71 loaded
99 chevy swb fleetside(daily driver)
Sparks, Nevada
frost89434 is offline   Reply With Quote
Old 05-08-2002, 12:33 AM   #5
imdarren
imdarren's Avatar
Post
Frost,
Thanks for the input. So, are you saying the towers are exactly the same a small block towers? Or, are you are saying they "will work"? I'm only asking because I'm planning on a high Horsepower motor, and only wan't to do this one time.
Also, is there a diffrence in the strength of a short vs long shaft TH 350 tranny?
Thanks? Darren
Darren
Washington State
1967 Chevy C10 LWB
Washington State
Old 05-08-2002, 07:23 AM   #6
69 longhorn
Post
The smallblock wont bolt on the 292 towers(they are staggered),it will bolt to the 6/250 towers,& take the same engine mount. I have mine set up on the 6/250 mounts,to move it back,but some guys dont like how tight the HEI dist fits to the firewall. On the factory V8 stands,the eng sits farther ahead(2wd). If you are building a hot smallblock,a little weight transfer can be a plus.......69longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 05-08-2002, 03:39 PM   #7
Kas68c10
Kas68c10's Avatar
Post
if the 292 needs a new home.let me know
1968 SWB Stepside, pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,3 bolt seatbelts, original i6 and wood bed, seat from an 89 Chevy, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,WORK IN PROGRESS,Daily driver, 20 MPG, Freeland MI
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!!
Kas68c10 is offline   Reply With Quote
