Old 06-25-2008, 08:34 PM   #1
"67"StepSide
Junior Member
"67"StepSide's Avatar
Exclamation bbc headers ??? for 67
Can anyone tell me if any headers fit on my 67 two drive big block? other than the 67-72 chevy??
"67"StepSide is offline   Reply With Quote
Old 06-25-2008, 09:37 PM   #2
Desert Rat
Desert Rat's Avatar
Re: bbc headers ??? for 67
I bought ones for a 73-87 truck and they fit fine. I did have to trim the frame to make the correct 68-71 style bb motor towers to fit. My frame was a '67 GMC.
Desert Rat is offline   Reply With Quote
Old 06-26-2008, 06:16 PM   #3
corn
I have Hooker comps for chevelle on my 69. Nice fit & tuck in the rails a lot better than truck headers. I did have to modify the trans xo a bit to tuck the pipes up to match the headers though...
corn is offline   Reply With Quote
Old 06-26-2008, 06:17 PM   #4
"67"StepSide
Junior Member
so they fit no problem? good to know i also trimmed my frame for motor mounts. i'm on to headers next, what brand did you get? thanks john
Old 06-26-2008, 06:37 PM   #5
1bagged67
I had a set of hooker super comps on my 67, part number 2841 for a 68 and up BBC.... Did not like them after I lowered the truck, they hung way below the frame and hit the ground when the bags where aired out... I seen that Corn used a set of chevelle headers on his truck so I bought a set of hooker comp headers part # 2455 for a BBC Chevelle... The only problem that I ran in to was the shift linkage hitting the collector and the driver side ART conrtol arm hitting the tubes. Moved the motor back about 1/2 inch and I was a happy man... well worth the time
1bagged67 is offline   Reply With Quote
Old 06-28-2008, 03:59 PM   #6
Desert Rat
Desert Rat's Avatar
I had a cheapy set of Flowtechs. I never had any trouble with them. I'd use them again for the same application.
Old 06-28-2008, 10:39 PM   #7
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
These also fit nice and do not hang below the frame..
http://store.summitracing.com/partde...0&autoview=sku
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
