Old 07-06-2008, 11:21 PM   #1
N2GMTrux
N2GMTrux's Avatar
Arrow Rear A/C Problem W/ 2002 Chevy Tahoe
My 2002 Tahoe rear A/C was working just fine on Friday. On Saturday afternoon when I got into my truck and turned it on the rear A/c would not work. I checked all the fuses for the rear A/C and even the relays. Everything seems OK but the rear A/c does won't to blow any air.
I would like to know if there is any other relays located in another location in this vehicle.
N2GMTrux is offline   Reply With Quote
Old 07-07-2008, 07:03 AM   #2
Re: Rear A/C Problem W/ 2002 Chevy Tahoe
I am about useless when it comes to AC. Hopefully one of our techers will chime in for you.
Old 07-08-2008, 12:17 AM   #3
N2GMTrux
N2GMTrux's Avatar
I looked into a Chilton manuel today. It basically said the front A/C setup can be checked in a conventional way with a test light to see if electricity is passing to the blower motor. The rear A/C it says to take it to a service dealer because it use electronic sensors which could be burned if tested.. Has anybody had trouble with there rear A/C on aq 2000 to 2005 Tahoes,,,,,,,,,,,, any advice greatly appreciated!!!!!!!!!! THANK You.......
Old 07-08-2008, 11:25 PM   #4
bwood
bwood's Avatar
Is there an override on the front A/C panel that prevents the usage of the rear? For some reason I was thinking there was a button on the dash of the previous body style Tahoes that prevented the rear A/C from being used.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 07-09-2008, 09:56 AM   #5
N2GMTrux
N2GMTrux's Avatar
No, there is not an override button. The rear A/C worked one day then the next day just stopped working. The front A/c works and is blowing cold air. The rear A/C does not blow anything at all. I think its the blower motor for the rear A/c located under the passemger side rear trim cover in the cargo area of the truck I'm going to attempt to check it this afternoon. Thanks
Old 07-11-2008, 11:11 PM   #6
bwood
bwood's Avatar
Don't forget to check the control head for the rear also. I have had to replace the control head on my truck 3 times.
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
