Old 07-08-2008, 02:08 PM   #1
gottwake
gottwake's Avatar
Suggestion re: my steering after dropping x member
I dropped the front x member 1.5" and need to make room for the steering. If I notch the frame 2-3" and raise the power steering pump, will this work? Any suggestions?
Blazer Project
gottwake is offline   Reply With Quote
Old 07-08-2008, 07:13 PM   #2
azfab
azfab's Avatar
Re: Suggestion re: my steering after dropping x member
hay dude i think i can help you out, when i droped mine i used double d shafts and flaming river ujoints and a hime. you can leave the box and frame alone where they are at. if you have any pics im me ill send pics
lifes short fabricate as much as you can!
azfab is offline   Reply With Quote
Old 07-09-2008, 12:27 AM   #3
gottwake
gottwake's Avatar
Pics would be pretty cool...thanks.
Blazer Project
Old 07-09-2008, 06:22 PM   #4
Slammed67
Progress = 0%
Slammed67's Avatar
I did this on another member's truck....
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 07-10-2008, 12:04 AM   #5
gottwake
gottwake's Avatar
Do the steering rods hit the frame?
Blazer Project
Old 07-10-2008, 05:05 AM   #6
oldspowered67C10
Im not sure if this will hep but if you dropped the frame 1.5" into the crossmember, to retain proper steering geometry and avoid bumpsteer you need the raise the steering box and idler arm 1.5" up on the frame. Im sure that if you didnt move them up itd drive OK but it wouldnt be right.
oldspowered67C10 is offline   Reply With Quote
