Old 05-08-2002, 08:26 PM   #1
Project1970
14.1 @ 96MPH
Project1970's Avatar
Post Quick 700R4 question
Okay, I'm probably going to get my 700R4 from www.phoenixhardparts.com, namely because they're local and that's a good price for a tranny ($750 after core). The core charge is the same regardless of the transmission style...if you go to their site, they sell them by year (82-86 or 87-92; year choice is a no-brianer, the 87-up ones are stronger), displacement (2.8, 4.3, or 5.7...the choice is easy, lol...), and 2WD or 4WD (here's where the choice gets interesting). From what I hear, the 4WD cases are stronger. The core charges are all the same...so, assuming the 4WD 700R4 comes with a tailshaft (since I believe newer ones have the transfer case bolt to the tranny in place of the tailshaft?), would that be the one I want for my '70 GMC? It's a mild 350, so a stock tranny should be more than fine.
Project 1970 - soon to be seen at http://milhouse.treylis.org:81/
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 05-09-2002, 12:32 AM   #2
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Post
the 4x4 case is different. The transfer case does bolt directly to the transmission and the output shaft in the tranny drives the splined hub in the t/c. unless there is a conversion kit or adapter I've never heard of, the 4x4 tranny won't work in a 2wd truck.
Ol' Buck: '72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84
ralleys and 31/10.5s
Angel girl: 67 Cutlass convertible
330, 3spd stick
Greener: 90 GMC Jimmy
350/auto
Chad Stephens
Orleans,NE
no name yet: 72 442 under serious construction
my site:
http://communities.msn.com/Beastonabudget/homepage
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 05-09-2002, 12:35 AM   #3
Project1970
14.1 @ 96MPH
Post
Ah, okay. That pretty much settles it then, heh. Thanks!
Old 05-09-2002, 07:47 AM   #4
1-PU70
1-PU70's Avatar
Post
I have heard the same thing to use a 4x4 case because there stronger. Also get the inspection cover for a 4x4 because its cast and ads more strenth.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 05-09-2002, 09:17 AM   #5
snowman1
Talking
the 4x4 will work but you have to change the rear shaft and the tail stock on the tranny. i have one and am getting ready to have it changed out to go in my 71 longbed. snowman
snowman1 is offline   Reply With Quote
