Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 07-22-2008, 12:43 AM   #1
silverado84355
silverado84355's Avatar
2008 silverado stereo swap
Hey guys, I am looking into replacing the factory deck in my 08 but I am afraid of what might be involved. What "kit" do I need, if there is one, to still keep my Onstar,Steering wheel controls and such working? Is this possible or will something have to go? I've just never been a fan of the crappy factory decks. Thanks in advance for the help!
silverado84355 is offline   Reply With Quote
Old 07-22-2008, 02:45 AM   #2
AceX
>130dB Moderator
AceX's Avatar
Re: 2008 silverado stereo swap
The factory deck really isn't all that bad...
There are a few different kits available, but there are several pieces that you will need. There's a module for the warning beeps, there's more complicaitons when using OnStar. If the truck came equiped with satellite radio, there's alot of variables to consider. My suggestion is to go to a local shop and talk to them. They may have exactly what you need.
Just know that it will not be cheap. GM has been using the radio to do all sorts of weird things for a while, so a simple swap, isn't really so simple anymore...
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 08-22-2008, 03:03 PM   #3
djracer
djracer's Avatar
I put a basic head in an 08 van and my wholesale cost on the parts without xm or onstar was almost 200.00! OUCH!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 09-19-2008, 08:48 PM   #4
Pyrotechnic
Pyrotechnic's Avatar
If you can get a nice 4 channel amp with speaker level inputs, you could replace all your speakers with nice ones and have a nice sounding system but still use the factory head unit.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 09-19-2008, 10:13 PM   #5
AceX
>130dB Moderator
AceX's Avatar
That's what we did in my dad's '06. Added a Peripheral adapter to get RCA's, then ran those to two ARC Audio amps and used those to power the MB Quart speakers and Pioneer subs.
Living Life @ 130dB
RIP El Jay
Old 10-15-2008, 01:53 PM   #6
AC72
AC72's Avatar
I did this in my 95 and 99. replaced speakers, added amp/subs, sounded good. eventually put new deck in 99, sounds even better. I didn't have onstar though. I would call and talk to the guys @ crutchfield. if you buy the deck from them, they usually send you the install kit for free, along w/instructions. it was pretty straight forward. good luck and keep us up to date w/pix!
AC72 is offline   Reply With Quote
Old 10-15-2008, 03:12 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Now I've got a question.... back a car or two ago, I took my vehicle in to have them add the rca's so I could keep the factory unit, but every time the vehicle would shut off you would hear a loud "thud" from the subs.
I have hooked up a ton of systems and never had this problem, but take it to an installer.... and what you do you get??? Problems!
I've thought about changing out the door speakers in my '08, but figured I would need to add an amp and what not.
Interested in more info on your install.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-18-2008, 08:28 PM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
bump for more info....
-Nate
Old 12-08-2008, 03:13 AM   #9
frostie_122
putting a radio in that vehicle will need a few things. a gm lan module if you have onstar and bose. a antenna adapter. a dash kit, and if you have steering wheel controls a module for that.
We sell the Peripheral products.
-Dash kit#BKGMK317
-Harness#GMAHLANB (onstar and bose)
#GMAHLAN (onstar w/ no bose)
#GMCOL29 (no onstar no bose)
These should come with antenna adapter (#BAA20)
-Steering wheel audio controls module (if equipped)
#PES-then jvc, or ken, on sny, depending on radio brand.
That "thud" you hear is turn on/off pop. Could be caused by a number of things.
Hope this is helpful.
frostie_122 is offline   Reply With Quote
Old 12-08-2008, 03:17 AM   #10
frostie_122
...and if you are going to a professional shop and they added a hi to low convertor, also know as a line output convertor, they should be qualified to make it work correctly. In my years i have never had a vehicle left the bay with that going on.
