07-24-2008, 01:06 AM | #1 |
replacing the wood floor in a surburban
... anybody done this, or have tips?
I have looked at it enough to realize it isn't as simple as I thought. I could probably make do with what I have but I have to make some repairs (we had to cut in from the top to remove a giant home-made gas tank installed by the P.O. and my original thought of "hey I'll get a nice sheet of plywood and coat it with a nice epoxy and install it" now seems naive. So, any advice? --steve
Help! My project parts hauler became a project! |
07-24-2008, 01:10 AM | #2 | |
Re: replacing the wood floor in a surburban
07-24-2008, 01:10 AM | #3 |
...or do planks and stips like a wood bed.
07-24-2008, 01:44 AM | #4 |
Luv the Crewcabs
Here is How it Could Look.............
Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
07-24-2008, 09:40 AM | #5 |
I wondered if a pickup wood bed type effort would work, that's a neat option. I'll give it some thought and see. (I'd probably still cover it with carpet but I do know I'd rather not remove the body and replace it from underneath, which is how it seems to be done at the factory.
07-24-2008, 10:33 AM | #6 |
its all about the +6 inches
if you are just going to cover it with carpet, then you can just patch the floor instead of replacing it.
07-24-2008, 12:27 PM | #7 |
Very true LHM.
Another option is to do cabinet grade wood in two or three sections then use the truck bed stainless/chrome strips to hide the gaps plus strips in between so it looks like planks. |
07-24-2008, 12:52 PM | #8 |
thanks for the ideas.
Patching it is probably the default. I know I'm not taking the body off the frame. :-) But looking at the condition of the wood, it's 35 year old plywood, if it were easier I'd definately replace it. That's my problem with my car projects is you start by replacing a missing screw and come to your senses when you realize your car is disassembled spread out across the garage. This is supposed to be the parts hauler for my project, not my project. :-) --steve
08-12-2008, 10:28 PM | #9 |
What?
I have done this... It wasn't fun. I had the body off the frame at the time, since I thought that was the only way to do it at the time.
But, if I had to do it again. The trick is that the corner closest to the 3rd door is actually a tongue and grooved section, and if you look close at it you should see the seam. There is S load of bolts holding it in, and just about all of them I had to chisle off. Once you get all of the bolts out, remove the spare tire well. Then dig out that corner I spoke about earlier, once you have removed the corner you will be able to shift the board towards the passenger side. Easier said than done, but since you are not gonna keep this wood.. Time to get the sawzall out! Use your original wood as a template for the shape, and use it as a template to drill all of the holes for the bolts. Once your new piece is all dialed in and the metal channels are clear of dirt and rust, install the floor from the rear until it settles into the channels. Once the board is settled, use a mallet to shift the board snug under the driver side rear fender well. Once that is done and lined up with all the holes, get your corner out that you duplicated from the original and tap that in place. Install your spare tire well, and finnish installing all of the carriage bolts. Be sure to use best grade plywood you can get, and then seal it all up especially on the bottom! I used a marine grade wood, which is much more durable and has a smoother finish. Marine grade will be expensive, but it will be money well spent! Good luck!
Chris 1968 K20 Suburban 1972 K10 LWB PU |
08-13-2008, 08:42 PM | #10 |
Junior Member
Clear something up for me.
I have a 67 panel that has a floor like the wood bed pick-ups have. I stripped out an overlay of 1/2 " plywood that a previous owner had installed and the wood is in damn good shape with only a couple of holes drilled in it. I'm going to just clean, stain & clearcoat the original wood planks. What year/s did they go to a plywood style floor? Last edited by PETEM1957; 08-24-2008 at 08:28 AM. |
08-13-2008, 09:30 PM | #11 |
What?
Well consider yourself very lucky that you have the PU style plank floor! I sure wish mine did, since it would have made my life easier. Actually I am suprised that your 67 has a plank floor... I always thought the 67/68's had a plywood rear floor, but I am thinking that there maybe something about your truck being a panel and mine being a burb with glass. I did see another 68 Panel that was for sale on the interweb, and in the video it showed that it had a plank floor. At the time I thought cool, someone made that work.. I guess panel models had plank, while the window models had plywood???
08-13-2008, 11:45 PM | #12 |
well, i thought my panel had individual planks, see below...
GIZZmotorsports on YouTube & my panel truck build '69 c10 panel, '75 c35 flatdeck car hauler Last edited by GIZZ; 09-08-2008 at 01:39 AM. |
08-14-2008, 05:13 AM | #13 |
Panels had planks, Burbs had ply from what I've seen.
08-14-2008, 07:16 PM | #14 |
Old School, New Style
Are the panels actually planks or do they just have the strips for utility/abuse protection purpose? Always been curious and have never inspected a panel myself.
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck |
08-14-2008, 09:30 PM | #15 |
I am 99% sure they actually have planks.
08-23-2008, 02:59 PM | #16 |
just a thought. how about replacing it with metal. a little easier to work with and last a whole lot longer. something to consider.
08-24-2008, 08:36 AM | #17 |
Junior Member
They are planks, you can see the different wood grain patterns. It is definitely not plywood.
08-24-2008, 02:36 PM | #18 |
Its always something!
The floor in my panel is plywood with the strips bolted to the top.
79 p10 stepvan 72 Short Fleetside 72 Suburban 67 GMC One Ton Flatbed 64 Short Fleetside 57 Chevy 2DR Hard Top 57 Chevy 2dr wagon 65 f*** short fleet 63 C 60 Flatbed Member of the patina club |
09-07-2008, 12:19 AM | #19 |
I always thought my Panel had plywood-I never really studied it that close. I'll have to take a closer look.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
09-08-2008, 01:30 AM | #20 |
ok, i just looked at mine. i know it may not help the orig poster much cause its a panel, not a burb. but for general interest its a '69 canadian truck, original floors. it has 2 sheets of roughly 5/16" thick wood covered by the metal strips. i woulda swore they were individual planks, here are the pics. you can see the divide line in the first 2 pics from the top. the last pics shows the underside, strip bolts down the edge of one sheet, and in the upper left or same pic a strip nut/bolt/washer in the middle of a solid sheet of wood.
GIZZmotorsports on YouTube & my panel truck build '69 c10 panel, '75 c35 flatdeck car hauler Last edited by GIZZ; 09-08-2008 at 01:38 AM. |
09-08-2008, 05:24 PM | #21 |
Thanks Gizz. That answers my question. Can anyone provide pics of a panel with factory planks? Sorry to hyjack this thread.
09-10-2008, 06:06 PM | #22 |
I am a Referee of life.
All of the panels I have seen were ply.I think it was a good quality marine grade but I haven't seen planks.They all look like planks from above but I seriously doubt there were different floors since the production was so small.I think the lip that covers the edge(holds it in) would be too small for a plank unless it was planed doen.I am just speaking from personal experience here as I do not have any documentation.Seems like it would have made it to the SPID.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
