Old 07-25-2008, 10:02 PM   #1
drman929
drman929's Avatar
Another budget 5.3 build...
I wanted a taste of the fuel injection world, and the opportunity to buy a real cheap swap setup arose, so here I am. I want this to cost under 2k, which I think I can pull off. Engine is a 5.3 out of a rolled '05 truck with 4l60e. The combo has 37,000 miles, and I got to pick whatever I wanted from the truck...so I came home with a truck full of crap...hehe
My 1,300 mile 350 rebuild came out easily and was sold to a fellow board member-
And tomorrow I am starting on the new engine. Cleaning it up real good, making adapter plates, and maybe start test fitting. I'm planning on doing the wiring myself, and using the factory tank from the '05. The only mod it will really have at this point will be a tune.
drman929 is offline   Reply With Quote
Old 07-27-2008, 05:56 PM   #2
RaceAGMC
RaceAGMC's Avatar
Re: Another budget 5.3 build...
Looks like fun, im starting a gen III swap myself. It is def the way to go these days. Good luck.
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 07-27-2008, 10:17 PM   #3
drman929
drman929's Avatar
Put in 10 hours today, this is how she sits. I pulled it out after this to enlarge a few holes and clean and paint the frame.
Old 09-09-2008, 08:48 PM   #4
drman929
drman929's Avatar
Been enjoying it for a few weeks, but I'm not completely done. Alot of cleaning up to do with wiring and small stuff.
I just built the intake and haven't got a chance to pick up a clamp, so that's why there isn't one if you are wondering.
Old 09-10-2008, 12:30 PM   #5
Rokcrln
Rokcrln's Avatar
Looks good I have an 05 DOD 5.3L with a 4L60 as well to drop into my 4dr burb build. It came out with 23k on it. EFI is the only way to go in my book!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 09-10-2008, 12:41 PM   #6
steelhorse
steelhorse's Avatar
What are you plans for the A/C?
steelhorse is offline   Reply With Quote
Old 09-10-2008, 01:07 PM   #7
BlueJeep
BlueJeep's Avatar
How close did you come to the budget?
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 09-10-2008, 07:20 PM   #8
drman929
drman929's Avatar
I haven't figured up my tickets, but if I'm thinking right I am pretty close.
Eventually I plan to use the '05 compressor by making new lines.
Fuel injection is awesome, it will be very hard to use another carbed motor in a project.
Old 09-10-2008, 09:26 PM   #9
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice install!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-11-2008, 04:38 PM   #10
63 & 64 Bowties
and a few others
Nice choice. Is that going in the truck in your avatar? One looks blue, the other gold.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 09-11-2008, 07:30 PM   #11
drman929
drman929's Avatar
Yeah, my avatar is the truck before I painted it. I'm now painting it again since it's a '68 Chevy instead of a GMC.
Old 09-11-2008, 07:45 PM   #12
sandking
.....I am working on it.....
sandking's Avatar
Looks good!! What did you do for motor mounts?
View my build thread HERE
sandking is offline   Reply With Quote
Old 09-17-2008, 10:05 PM   #13
drman929
drman929's Avatar
I made plates out of 1/4" and welded clamshells to them.
Old 09-18-2008, 09:55 PM   #14
kamikazekyle05
kamikazekyle05's Avatar
I see you did the wiring yourself, can you tell me what wires you had to remove or combine?
kamikazekyle05 is offline   Reply With Quote
Old 09-18-2008, 10:25 PM   #15
drman929
drman929's Avatar
Well, I removed a lot of unnecessary things like the lights, but as far as actually wiring it to run, I had a set of wiring diagrams that I went through and hooked to my existing wiring to make it run. Take a look at LS1tech and do some searching, and you will find your answers. What year motor do you have?
Old 09-19-2008, 10:56 PM   #16
kamikazekyle05
o I dont have a motor yet just trying to get an idea of how involved the wiring removal is
Old 09-22-2008, 10:27 PM   #17
drman929
drman929's Avatar
It's not really that bad. Much easier than I thought it would be!
Old 10-10-2008, 09:29 AM   #18
paisaloco67
Nice job, question,,,,when u swap a 5.3, where do you get the vacum for
the brake booster?
paisaloco67 is offline   Reply With Quote
Old 10-10-2008, 10:54 AM   #19
BlueJeep
BlueJeep's Avatar
I believe the 5.3 has provisions for you to pull vaccuum from the intake for the booster, just like in the 99+ truck you pull it from.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 10-10-2008, 07:53 PM   #20
drman929
drman929's Avatar
I even used the factory '05 hose. It sticks out, but works for now!
Old 10-14-2008, 12:14 AM   #21
paisaloco67
drman929 What where the unecessary codes or things u had to remove
from your pcm? Did u use your stock tailamp brake switch for the tranny
locking sensor? I have the same motor tranny setup that I just got out
of an avalanche (8900) miles. I dont know much about mechanical stuff
but I know I can do the swap into my 72 with some help of the pros in this site, any help will be appreciated.
Old 10-14-2008, 12:18 AM   #22
paisaloco67
got it! I just took a peek on the back of the intake and saw a plug. thanks
blue jeep
Old 10-14-2008, 08:23 PM   #23
drman929
drman929's Avatar
I had Jesse at W4M give me a 93 octane tune. When he programs, you don't have to do anything computer wise. I had him remove my rear oxygen sensors, since I removed the cats. I used my factory '72 brake light switch, but wired it up with a 5 prong relay to take power away from the purple TCC lockup wire and supply it to the brake lights when I hit the pedal.
Wow, nice pullout!!! I am really loving mine, it has so much more power than my 350. It will snap your neck back!
Old 10-15-2008, 10:14 AM   #24
paisaloco67
drman so u ended up using the 05 fuel setup? isnt the 05 fuel tank a little
big for our trucks? How u did this?, also, whats the other black plastic line
running along with the fuel line on the engine?? is that line used when performing the swap? thanks
Old 10-15-2008, 09:27 PM   #25
drman929
drman929's Avatar
For now, I put the factory tank in a toolbox in the bed. The other line is for the evap stuff, not necessary.
