07-29-2008, 10:16 PM | #1 |
how dificult
ok guys, i have a 80's something 4x4 s10, no title. i would liek to make this truck a drag truck only toy and i have just the engine. its a sbc 400 with a th350 behind it.
now my question is, how dificult would it be to turn this 4x4 s10 into a 2wd style drag truck? worth it? after all, the truck was given to me and the engine and tranny are just sitting in my garage. thanks guys for your input. i hope this turns out do-able. |
07-29-2008, 10:26 PM | #2 |
Re: how dificult
That all depends, I wouldn't bet on the diffs to handle much more than stock power. The swap isn't much harder than doing it to a 2wd. they make a special oil pan you would need to in order to fit over the front diff. everything else should be the same as for difficulty.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
07-29-2008, 10:32 PM | #3 |
Re: how dificult
well wouldn't the front diff and all that come out?
and this is going to be a drag truck....the rear dif will end up being a shortned 9" more then likly. |
07-30-2008, 12:03 PM | #4 |
Re: how dificult
8.8 rear out of a leaf rear explorer is a direct bolt in. thtas the rear most swap in as they are real stout.
72 chevy 3\4 ton 4 speed 4x4 84 1\2 ton 4x4 (gone but not forgotten, thanks for the memories) 1999 suburban 4x4 1982 chevrolet S-10 V-8 (Thanks uncle EARL) |
07-31-2008, 10:14 PM | #5 |
Re: how dificult
Oh since that's the case, And since I didn't read clearly your first post. I would suggest comparing the frame's between a 2wd and 4wd. I think they are different. I remember awhile back I had a 4wd parts S10. And I had looked at doing just the opposite to a 2wd I had. It was going to be more work than I wanted to get into.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! Last edited by BarryB; 07-31-2008 at 10:15 PM. |
08-16-2008, 09:55 PM | #6 |
Re: how dificult
Yes, front frame sections are different. There was a guy in my town that did one years ago. He cut off the front end and welded a 2wd frame stub back in place. He said it was the best option.
