08-23-2008, 10:58 PM | #1 |
I guess I should post my build thread on my '69 C10 now...
Hey guys, I've owned my '69 C10 for a few months now. I traded a good buddy for it straight acrossed for a 1974 K5 I had. Although my K5 was in alittle better shape, I've always wanted a '67-'72 C10.
After getting it home it was clear that it had some issues (which I was warned about). The biggest one ended up being a flat cam lobe. After tossing a few ideas around I decided to bite the bullet and swing for an LSx swap. A local wreaking yard had a 5.3 with 37k miles on the clock from a rolled 2004 'Burb for $700 and it included everything (PCM, harness, gas pedal, etc). Later I scored a 4L65e from a wreaked 2004 GTO with 13k from LKQ for $800. I sent off the harness and PCM to Wait4Me Performance to convert the harness for stand alone operation and edit/tune the PCM for removal of the various smog/emissions stuff and the VATS. They also included a performance 'canned' tune for the PCM. I should have it all back by the middle of the week. I also sprung for Hedman long tube headers (Torque-Step) intended for a '98-'02 F-Body . I am having to modify the headers with a few dings with a hammer and grinding the frame a bit to make them work. In the meanwhile I also bought a complete front clip from a '67 C10, Walbro 255 inline fuel pump, Corvette filter/regulator, frame-rail style tranny cooler, '71-'72 power booster, Brothers tubular engine stands, GMC Paul's tranny cross-member, Trans-Adapt LSx motor mount adapters, rear roll pan, front 3" drop springs, Slam RE7 (rear) bags, nitro-drop shocks, ECE adjustable track bar, second row Tahoe leather 60/40 split bench seat, and few other odd and ends. Today I installed the engine and tranny with the new tubular engine stands and the new tranny cross-member. It all went fairly well, no major snags except the headers (which I expected). A buddy is making some changes to the headers, including cutting off the smog/AIR injection tubes and welding them shut. Sometime this week I am modifying a rear coolant plug to accept a electric sender for an Auto Meter water temp gauge. I am also drilling and tapping a oil block off plug to accept a manual oil pressure sender. Among others things, I have to mount the gad pedal, install the electric fuel pump as close to the stock tank as possible, install a return line in the stock pickup, run a return line from the Corvette filter/regulator (after installing it), run a fuel line from the end of stock fuel line to the fuel rail, install/plumb the frame-rail mounted tranny cooler, and of course install the re-worked harness and PCM. Later I'll swap to the '67 front clip, change the various suspension stuff, and hopefully I'll have the funds to ditch the 'Dukes of Hazzard' rims (AR Vector) in favor of some 20's pieces. Updates as they follow...... Thanks guys!!
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 Last edited by Ford Assassin; 08-04-2009 at 01:52 AM. |
08-23-2008, 11:16 PM | #2 |
I have a radical idea!
Re: I guess I should post my build thread on my '69 C10 now...
Sounds like an awesome project. I like that you're staying with the stock tank also. Can't wait to see the progression on this one!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
08-24-2008, 02:12 AM | #3 |
This looks fun, I wish I had a short bed. I love LSX motors
08-24-2008, 10:55 AM | #4 |
I think you should put an 01 on the door, paint it orange, and leave the rims on there..................., JK. Good luck with your build.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-24-2008, 11:09 AM | #5 |
high-Tech Red Neck
Welcome to the club, Good luck with the build, it sounds like its going to be nice.
"He used to be a pretty nice feller, now he's a welder!" |
08-24-2008, 12:36 PM | #6 |
Under Construction
nice looking project. Good luck with your build.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
08-27-2008, 01:44 PM | #7 |
Pics!!!
Pics for you guys......
08-27-2008, 01:54 PM | #8 |
high-Tech Red Neck
Saweeeet!
08-27-2008, 03:49 PM | #9 |
got any pics of how you did the coil relocation??
08-27-2008, 04:35 PM | #10 |
I am not sure I know what you are asking. If you mean the coil packs, I am going to put them back in the stock location mounted on the valve covers.
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
08-27-2008, 05:50 PM | #11 |
yea, i was talking about the coil packs, sorry i thought you had them mounted on the backside of the head....upon second look thats the block (red) not plug wires i was seeing
08-28-2008, 01:43 AM | #12 |
No biggie. I wish I knew of a way to re-locate them though. I personally think they are the ugliest thing on the LSx motors. No wonder these things always had engine covers.....
08-28-2008, 09:12 AM | #13 |
Ive seen these with the MSD coils on them it gives a splsh of color to the motor.
09-01-2008, 10:13 PM | #14 |
Well I got the modified PCM and harness back from Wait4Me and plugged everything back in today. Still have to mount the PCM somewhere on the driver's side, prob on the inter fender well. I also have to wire up the the harness for stand-alone operation (3 ignition switched and 1 constant 12 volt) fuel pump and relay.
09-02-2008, 08:25 PM | #15 |
Keep Your Nose Clean
I dig the way those new engines can be adapted to the old trucks. Looking back, I should have gone that route.
09-02-2008, 08:53 PM | #16 | |
09-02-2008, 09:02 PM | #17 |
or you could hide the coils like this
09-02-2008, 09:41 PM | #18 |
Tot Roddin'
That motor looks nice tucked in between that old sheetmetal.
Sweet looking project!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
11-06-2008, 05:22 AM | #19 |
Looks good anything new
11-06-2008, 12:21 PM | #20 |
Yeah, I am about done with the swap, just a few more wires. The project has kinda been on hold due to buying a house and then getting married last weekend. Then I am going on my Honeymoon this weekend and I have a buddy's wedding to attend the weekend after that. Soon all that's over with I can get back to playing with my truck.
My plan is to have the motor at least fired up before the end of the year, time will tell....
11-06-2008, 04:07 PM | #21 |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
11-17-2008, 10:07 PM | #22 |
Very cool project - interested to see more. I'm seriously considering an LSX replacement for my BBC.
72' LWB Cheyenne 73' Camaro Z28/RS 70' Chevelle RagTop 00=ss=00 |
12-15-2008, 01:27 AM | #23 |
Okay guys, time for an update.
The swap is 99% complete. I could of fired it up tonight, except I have two things holding me up. First I have to have a custom power steering hose made, which I am having done tomorrow morning. I didn't want to risk burning up the pump. Second is all I have hooked to the car is stock '98-'99 F-Body manifolds and nothing else. I might fire the motor for a second, just to confirm it runs, but again I don't want to risk burning/bending a valve if run too long. Here's the bad part. Even if everything goes according to plan I am flat outta cash for an exhaust for the time being..... or at least for a month or so.
12-16-2008, 12:23 PM | #24 |
Where's the love guys?
Okay, I have the power steering hooked up. Guess what? With the very first crank of the ignition it fired right up. I only let it run long enough to check the oil pressure (60+ psi) which was only about 15-20 seconds at most. Now I am on the hunt for exhaust flanges for my '98-'99 F-Body manifolds, which I am finding no one carries.....
12-16-2008, 05:17 PM | #25 |
Cool build. Good luck on the 'hunt'.
