Old 09-01-2008, 10:24 AM   #1
Critter
Future TOTM Winner
Critter's Avatar
Talking Man shop Ideas
I am trying to save up and build a shop sometime in the next few months. I know a few basic things that I am shooting for. I thought I would bounce it off of the brilliant minds here and see if I am missing anything.
60x40x12ft tall metal building
6 inch concrete slab
2 large doors (probably roll up but maybe barn style) and 1 man door
Fully plumbed for multiple air outlets
High bay fluorescent lights because I HATE dark areas when I’m trying to work
Eventually a lift of some sort, still haven’t decided exactly which style.
Vented roof and an exhaust fan for the Texas heat
I don’t think it will be insulated in any way.
Some sort of floor sealant…still deciding on that as well
Plenty of electrical outlets for power tools including my cracker box welder, air compressor, maybe even an upright mill and lathe if I can find some nice used ones.
Some sort of internal structure that will support a 2 axis overhead hoist
Of course lots of bench and work areas along with storage bins
So anyway, is there anything that I have missed? Any tips or suggestions that I should know when planning construction? Anything you wish you would have done differently when you built yours. By the way, this will be behind my house and I plan to spend A LOT of time there so I want it to be perfect. I plan to use it for everything from restoring cars/trucks to changing the spark plug on the riding lawn more. Not to mention my everyday tinkering and playing around (beer drinking).
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 09-01-2008, 10:31 AM   #2
BarryB
BarryB's Avatar
Re: Man shop Ideas
Sounds good, But I would definitely put insulation in. Will help with the heat. And being that big I would probably put in 2 exhaust fans. One on each end. one to pull air in and the other to push it out. And I would probably take it up to 14' ceilings. A friend of mine has a garage with 12' ceilings and a lift. unless your short your having to be hunched over under a truck or car because you can't raise it high enough before hitting the ceiling . well at least have the roof raised in the lift area.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 09-01-2008, 10:34 AM   #3
fun in dirt
fun in dirt's Avatar
Re: Man shop Ideas
Be sure to have big doors on both ends, for plenty of airflow. (But being that size it probably will anyway.) Saying this because our shop doesn't & it makes it that much hotter!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'06 3500 Duramax ...tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 09-01-2008, 10:35 AM   #4
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: Man shop Ideas
60x40x12?
12 = ceiling height? My uncle has 15ft ceilings in his shop, he cant lift his trucks all the way up.
Other than that good idea!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 09-01-2008, 10:43 AM   #5
Critter
Future TOTM Winner
Critter's Avatar
Re: Man shop Ideas
Good points. I should have clarified; I plan for it to have 12 ft eves and a peak of 14 or 15 ft. I’m about 5’10”, so that should be decent enough for me to work under my lifted K5 or my 2500 4x4 Ram, right? Of course it depends a lot on whether it’s a tire lift or a frame lift. I am leaning towards frame.
As far as the insulation goes, I know you are right it is just money that I could put other places. If I did insulate what type should I use, the blow in stuff or the plastic layer type that goes between the structure and the outer tin?
Old 09-01-2008, 10:47 AM   #6
Critter
Future TOTM Winner
Critter's Avatar
Re: Man shop Ideas
Originally Posted by thirdstreettito View Post
60x40x12?
Alright, taller it is!
Anybody have an idea of what is optimum, 16ft, 18ft peak??? We don't get any snow so it will be a fairly flat slope, probably 1:12.
Old 09-01-2008, 10:47 AM   #7
msgross
msgross's Avatar
Re: Man shop Ideas
I've seen that foil type used inside the skin, between the structure.
Toilet and wash sink....for sure
Couch, TV, beer fridge and satellite to hide from the wifey....
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 09-01-2008, 01:21 PM   #8
BLUE THUNDER
BLUE THUNDER's Avatar
Re: Man shop Ideas
Lots of tools,a refridgerator, a stereo, and maybe a t.v. Oh yeah, you'll need a big a$$ shop fan. Mario.
BLUE THUNDER is offline   Reply With Quote
Old 09-01-2008, 01:28 PM   #9
k-nuts
k-nuts's Avatar
Re: Man shop Ideas
A/C.
I know, I know, but you said "perfect"!
Its only money, right?
I agree on some type of insulation definately. Or at least at some point in the near future. I made sure to fully insulate my 3 car garage (attached to house) and it doesn't get hotter than 85 or colder than 55. A little relief when its over 100 outside.
k-nuts is offline   Reply With Quote
Old 09-01-2008, 02:03 PM   #10
umwtnt
umwtnt's Avatar
Re: Man shop Ideas
Definitely a water supply and probably a deep sink of some sort. It's always nice to be able to wash smaller parts or even your self, and also good for washing the shop floor down which reminds me, water drainage. You also want to make sure you have good drainage around the shop to keep water from flowing into the shop during bad rain storms, or hurricanes like you may feel a part of soon. Direct lighting over your benches and tool areas. I would draw out what you envision and walk yourself thru a project to see if your plan is workable. Storage of parts, engines, frames and body parts, spacing of tooling and equipment. You mentioned exhaust fan, remember that will come in handy for when your grinding, welding or painting, make sure it's of adequate size. Designate a corner for a office for storage of books, files, plans, a dustless area for the computer to talk to us, or just a place to sit and think. Think about leaving a corner open in case you want to erect a pvc or pipe frame paint booth. Good luck and enjoy, building a shop is as much fun as building a truck.
The more I learn, the more I find out I don't know.
69 Chevy SWB w/67 front end
4 wheel discs
468 BB 700R4
Bagged
Coming around slowly
umwtnt is offline   Reply With Quote
Old 09-01-2008, 03:22 PM   #11
Critter
Future TOTM Winner
Critter's Avatar
Re: Man shop Ideas
All good points. I do have to point out that it will be about 75 yards from my house and there is a dry creek bed in between. There will be power run overhead by the power company, but I am not sure what to do about water. Because of the solid rock creek bed, I cant run a buried pipe. I could possibly run some sort of flexible UV resistant piping on the surface or something...still not sure about water. I have also thought about a small 200-or-so gallon tank trailer that I could pull to the house and fill up then take back to the shop for hand washing/general use. It will probably just drain out away from the building. I plan to have a self-contained parts washer for the major parts cleaning. As far as toilet, that is a whole other problem. Doubt it is possible, however, because of the remoteness of my property, the north side of the shop will easily double as a urinal
I have already gone over this in my head. I eventually want a 2x4 and plastic sheet “booth” to try my hand at spraying different coatings.
Old 09-01-2008, 04:31 PM   #12
thirdstreettito
Resident of Here
Re: Man shop Ideas
I'd say 20 tops. But 18 should do just find, with about 6'6 under the truck, that is if the lift you get goes that high.
~Bradley~
Miss having a truck
Old 09-01-2008, 04:53 PM   #13
Keep on Trucking
Keep on Trucking's Avatar
Re: Man shop Ideas
I built my shop with 16' roof. I can lift my 70 4x4 all the way up and have plenty of clerance up top and at 6'2" I can walk under it without hunching.
The vinyl lined fiberglass insulation is very easy to install.
You might even think about a safe of some kind. I like the kind that get set in with concrete when the slab is built.
You should get roll up doors. If you get track doors it can interfere with overhead space. Power doors are nice to.
An alarm?
Space for wharehouse pallet racks? They will hold most anything.
1970 4X4, Big block 454, 4 speed, vintage air, Mahagony wood bed, Tilt, tach.
Can have new owner for the right price.
"Life is tough, its tougher if you are stupid" (John Wayne)
My buddys truck for sale here.
http://67-72chevytrucks.com/vboard/c...p?product=2676
Keep on Trucking is offline   Reply With Quote
Old 09-01-2008, 05:29 PM   #14
Long Roof
Old School, New Style
Long Roof's Avatar
Re: Man shop Ideas
I recommend a MIN. of 14' clear below the ceiling. As been said already be aware of the o.h. door tracks and raised door when positioning a lift. I would also not go without insulation but be sure that the place can be sealed of from birds or they will get into the insul. and build nest. AC is pretty easy to do if you have good insul. One large or a couple small window units work fine if you keep the doors closed. Make sure you have 220 power for all the heavy duty stuff and I would go with a min. of 200A. panel.
My dad has a pole barn with one o.h. door and one man door. 12" of insul in the ceiling and 6" of insul in the walls. All drywalled, no windows and one AC unit. He also has two old style piston lifts (which suck). He can keep it at 75 all day long in 100 deg summer heat.
The Good:
- 72 GMC Jimmy 4x4 - 307 cid / 350 th
- 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th
- 96 Chevy Impala SS - mainly stock
- 98 Chevy Tahoe LT 4x4 - all stock
The Bad:
- 86 Chevy Suburban 1/2T 4x4 - winter beater
The Ugly:
- 72 Chevy Suburban 1/2T 2wd - parts truck
Long Roof is offline   Reply With Quote
Old 09-01-2008, 06:07 PM   #15
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Man shop Ideas
My shop is 40 x 60 with 14 foot sides. I don't know how high the peak is. I'm pretty satisfied with my shop's size but hate the fact that there is only one large door and it is not wide enough! Going in with a motor home or a loaded hay trailer is a pain. Heck, just having my 69's large side mirrors makes for a tight fit. I would like a big door on the opposite end for sure.
Lots of good suggestions but I'm thinking you need to run a high speed internet line out there so you can connect to your buddies when you're in the man cave!!!!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-01-2008, 06:52 PM   #16
haus
MMMM Ramen!
haus's Avatar
Re: Man shop Ideas
Good one Yukon. Definitely need to access the board without having to get all cleaned up and inside.
Phone drop might be good too - so you can order pizza...
- 1970 chevy blazer
haus is offline   Reply With Quote
Old 09-01-2008, 07:32 PM   #17
72freak
Rottenwood Garage Member
72freak's Avatar
Re: Man shop Ideas
60x40x12?
I have 15' 7" from the floor to the trusses in mine and I have a truck lift. I am 6'2" and I can stand under mine with a truck, Suburban or Excursion on it.
Might not be your "cup of tea"......but we have a stripper pole also!!!
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 09-01-2008, 08:09 PM   #18
Critter
Future TOTM Winner
Critter's Avatar
Re: Man shop Ideas
I really appreciate the input guys. I am a licensed electrician and currently I work for the largest electrical distributor in the world. So don’t worry, this thing will be lit up like the 4th of July and have an outlet about every two feet. It will be getting its own meter loop with a 200-amp main so I will never be without “Juice”.
Y’all have really got me thinking about the whole “A/C” thing. I have never really thought about that because so few people around here have it in shops, but you know, why not??? I think I am going to build the building myself from 5in pipe and C purlin so it probably won’t be a kit. I will have to get a few quotes on insulation costs. Also, I would like to have industrial style roll up doors (no tracks) but if I had to save a little cash somewhere, how bad would barn doors be??? I guess keeping it fairly airtight would be harder in that instance.
Old 09-01-2008, 08:26 PM   #19
72freak
72freak's Avatar
Re: Man shop Ideas
Polly type spray foam insulation would probably be $15,000. Batt would be about $10K I bet.
Old 09-01-2008, 08:30 PM   #20
Keep on Trucking
Re: Man shop Ideas
Down here I can not get insurance with barn doors because of the wind rating or lack of a rating I should say.
Something else to consider when you do get a lift. Do you want a stationary lift or one you can move around. I bought a Autolifters lift and it can be moved around even with a car on it. What is nice is it can be moved outside to do dirty work like power washing the under carrage.......
You have to have a driveway bell for the shop to.
Old 09-01-2008, 08:30 PM   #21
72freak
72freak's Avatar
Re: Man shop Ideas
You can find mid grade roll up non insulated doors for $700. I have 2 10x12 and 2 12x 14 and I didnt pay more than $625 for each. Roll up IS the way to go!!!
Old 09-01-2008, 08:39 PM   #22
Critter
Future TOTM Winner
Critter's Avatar
Re: Man shop Ideas
D@mn, didn't expect quite that much. Gonna have to keep saving.
Good point, I will have to do more research on this. I had always invisioned it being stationary, but you bring up a good point.
That's a reasonable price, and I only plan on getting two so I can probably afford that. What are the dimensions of your shop?
Old 09-01-2008, 08:49 PM   #23
thirdstreettito
Resident of Here
Re: Man shop Ideas
Well, my uncle has a 91 Cummins 4x4 D350 SRW. So it looks like it has a 4" lift. And we put a utility body on it last summer. He hates the low ceiling. He also cant put his 96' Powerjoke 4x4 all the way up either.
~Bradley~
Miss having a truck
Old 09-01-2008, 09:01 PM   #24
red69ss
Burnouts are therapeutic
red69ss's Avatar
Re: Man shop Ideas
I would consider attic space ,60 x 40 is big (mine is 30 x 40 and packed now) ,but you will be suprised at how quickly it fills up. my roof is 5 on 12 and I ordered trusses with attic space only 5 dollars more ,so I have an additional 8 x 40 storage space in attic with attic ladder which limits what you can put up there but saves floor space . good decision to go with taller cieling wish I had did that only 9 ft now ,good luck and there is nothing like having a shop to work in it beats being a gravel mechanic anyday
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 09-01-2008, 11:22 PM   #25
69 K-5
69 K-5's Avatar
Re: Man shop Ideas
I have a 40x60 with 16' side walls with metal span trusses. I wanted the heighth in case I bought an RV.
One thing I wished I had done was to install a couple floor drains.
Also, I have a friend that just built a shop for business and he installed a 4" floor vent to hook up exhaust to vent to the outside through the slab. That sounds elaborate, but it would be less than a hundred bucks to lay that out before you had your slab poured.
!969 K-5 Blazer
1973 Pontiac Grand Am
2004 Chevrolet Avalanche
2004 Jeep Wrangler
69 K-5 is offline   Reply With Quote
