Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 09-09-2008, 06:38 PM   #1
Prerunner1982
Prerunner1982's Avatar
Pitman arm on 97 Blazer
Just by looking at it...it appears I have to remove the steering box to change out the pitman arm.. Is this correct? IF so... who is the idiot that designed that? What a PITA.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 09-09-2008, 11:53 PM   #2
corn
Re: Pitman arm on 97 Blazer
2wd or 4wd?
corn is offline   Reply With Quote
Old 09-10-2008, 06:53 PM   #3
Prerunner1982
It's a 4wd... and there is a crossmember less than an inch below the steering box.
Jon
Oklahoma Roll Call
Old 09-12-2008, 08:15 AM   #4
68C15
blood type; Retumbo
68C15's Avatar
remove the input shaft, remove the 2 forward box bolts, loosen the rear one. remove the pitman from the center link. tilt box upwards as far as possible and tighten bolt. use air cut-off to make a slit in the arm almost all the way through. be carefull to not cut the box or go too deep and damage the sector shaft. use chisel bit in air hammer to finish the split and at same time drive arm down off shaft. reverse procedure. then get an alignment as they just cant seem to make the new arm with the same clocking which makes your wheel crooked.
OTC makes a special puller for this but I usually end up doing it my way in the end.
opps, forgot to mention you should take out the 2 bolts that hold the brake line and ABS harness to the X member and relocate them to the rear for the process.
Last edited by 68C15; 09-12-2008 at 08:17 AM. Reason: partly cloudy outside, partly sunny in my head
68C15 is offline   Reply With Quote
Old 09-29-2008, 10:19 AM   #5
454_72_4X4
454_72_4X4's Avatar
That would be the same idiot that designs almost everything the same way now days!
Seems like there's always something in the way or ya have to remove something else to get at the part ya need to get to.
Not familiar with 4x4 S-10's myself.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 09-29-2009, 01:44 AM   #6
petty
i'm not so technical when it comes to these kind of modifications but I'm sure, it's 4wd.
petty is offline   Reply With Quote
