09-14-2008, 10:36 PM | #1 |
2008 Corvette Rims On a 72 SWB
Okay, i have the corvette LS1 in my truck and i figure why not make it a "corvette Truck". Ya know switching over steering wheel and such, just little tweaks. I wanna put on some new corvette rims SIZE AND SPECIFICATIONS: 18x8.5 +56mm offset & 19X11 +64 or +79mm offset. The lug/bolt pattern is 5x4.75 (120.65mm). I think the stock bolt pattern is 5X5 on my truck but with an offset rim and all that good stuff what kind of adapter plate do i need? someone out there has done this so please help me out. Thanks
09-14-2008, 10:50 PM | #2 |
Re: 2008 Corvette Rims On a 72 SWB
white_paper_180 to this site. Hang in there and someone will be able to help you out. Hey...why not consider becoming a member? It will be the best $25 you will ever spend on your truck. Just click on the subscribe sticky. Good Luck with your project. Sounds like you a great truck. Would love to see pics.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
09-15-2008, 12:03 AM | #3 |
Welcome to the board!
The corvette wheels won't work well, they are going to be so far tucked in it won't look right at all and you just might tip over on a corner. What I'm coming up with on the rear is about 8.5 inch backspacing with a +64 offset. You need to be around 5 inches of backspacing + or -depending on if you have the narrower 67-70 rear or the wider 71-72 rear end. I'm guessing you have the wider rear so you are looking at about 3.5 inch spacer on each side just to keep from rubbing on the bedsides. The fronts are going to need about 2 1/2 in spacer. That size of a spacer for the front and/or back is really going to load the axles and bearings and more than likely be very unsafe. I'm also not sure of a cost-effective work around for that either but anything is possible with time and money. That's just my two cents.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 Last edited by whatnow123; 09-15-2008 at 09:41 PM. |
09-15-2008, 04:35 PM | #4 |
Interesting. Are there any rims that maybe i could throw a corvette center cap into that would still be the 10 spoke design? http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=160281557783 i would like something wider on the back end too. 12 across would be enough for me
09-15-2008, 04:51 PM | #5 |
Insert Title Here
with the right size adapters they wont be tucked in
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
09-15-2008, 05:15 PM | #6 |
That's a nice look!! ...and it's GENUINE CHEVROLET too.
www.gkautospa.com Like A Rock! http://67-72chevytrucks.com/vboard/s...d.php?t=397153 |
09-15-2008, 05:47 PM | #7 |
Agree 100%. You'll need the proper billet adapters & it can be done. The key will be finding tires that will work w/those rear wheels & still be proportionally good on a truck. Tires that fill the wheel wells are what you need.... anything less doesn't 'look' right. Since your going through all the effort to adapt the wheels, don't botch it here.
Some 5x5 to 5x4.75 adapters remedy the bolt pattern issue. Use 2.0" thick adapters in front for a 4.95" calculated back-spacing w/the 8.5" wheels & use 2.0 or 2.5" adapters for the rear w/the 11" wheels. The difference will depend on the rear housing (early or late version). Front tires: Try a 255-45-18. It calculates out @ ~26" tall & has a 8.5" wheel within it's recommended widths. A less popular but better size (better meaning proportionally correct vs. the rear tire/wheel combo) would be a 245-50-18. Rear tires: The only rear tire that comes to mind was available for a factory vehicle (F**D GT-40) & should work. It was a 315-40-19 which calculates to be ~28.9" tall so it would work well on these trucks. The 315 section width has an 11" wheel within the recommended widths. Google 'billet wheel adapter' for adapter sources; the same thing for those particular tire sizes should locate some options from different suppliers/manufacturers. Have fun . . .....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-15-2008 at 05:49 PM. |
09-15-2008, 06:41 PM | #8 |
laying low
Here is another one with Vette wheels that looks pretty good.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
09-15-2008, 08:39 PM | #9 |
Your Trucks Look AWESOME!. i love the look but i really want the newer style rim. http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=160281557783 my truck is also bagged so it tuck's pretty good. not too low, its just got slam specialties bags, no notch no drop spindles. good advice for tires btw thanks alot
09-15-2008, 08:41 PM | #10 |
Also what adapters were used on those trucks above?
09-15-2008, 08:44 PM | #11 |
HERE.......Somewhere
any pictures of the truck with motor and rims
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 with a 350 4barrel and 288 horses Classics make it possible! |
09-15-2008, 09:51 PM | #12 |
Long Fleet Club
added the pic for others to see
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules |
09-16-2008, 10:29 AM | #13 |
Licensed to Thrill!
Post up a picture of your truck and somebody will slap those on for you.
(I have the wheels already edited in a .psd if anyone beats me to it after it he posts a pic, just e-mail or pm me). DLB |
09-16-2008, 11:29 PM | #14 |
i can photo shop. i Know it'll lok great, but i want to know how to do it
Tags |
adapters, corvette, pattern, rims |
