Went over to Tucson this weekend to pick up the truck. Got back Saturday night. Paid $1500 for it. It's not in too bad a shape. PO had parked it 2 years ago. Said it ran fine when he parked it.
He advertised it as having a 235, but i'm pretty sure it's a 230. Manual granny 4 speed on the floor. 1 BBL Rochester B carb.
Re: Finally got my truck now Let the fun begin
Spent all day Sunday trying to get it to run. Here's a breakdown of what I did.
Tried to start her up and after several attempts got it going for all of about 40 seconds before she died. Figured I had the timing off. Because as I was in the epic struggle to remove the oil filter, I had accidentally rotated it. So I started messing with the timing things to try and get it back to where it was. Finally the wife said enough.
Monday spent messing with timing some more. Found a few burst fuel lines. After about the 3rd one I said screw it, and ran to the FLAPS to get replacement fuel lines for every fuel line I could see. After that messed with it some more but no luck.
Today, was at it again after work. While messing around with the carb to make sure it was working, I noticed the idle speed adjustment was way off. So I adjusted it some, gave it a try and it fired up. It wasn't the smoothest, but after a little more adjustment, and adjusting the mixture a bit to get a nice stable idle I figured it was set. I messed around with the distributor a bit more to get it a little more dialed in. Then I eased it out of the driveway and into the cul-de-sac so I could do some donuts with my son ![]() ![]() I tried some more adjustments but can't seem to get it started back up now. Although every once in a while if I stomp the gas or pull the choke out it'll start, but if the choke is out it revs way to high for idle, but if I push the choke back in it dies again. So for now I'm kinda clueless about what to do next. Any Ideas?
1 thing at a time is progress.
It's got some issues as you well know, but it looks like a good start. Good luck and keep us posted.
Alan
Philippians 2:14-16 |
Yup has issues. Rust isn't too bad, passenger cab corner, drivers side rocker, both front fenders have rot in the rear and DS fender at the front is a bit smooshed.
But a pretty good interior/cab. I'm gonna try and get some more detailed photos tomorrow. Hopefully, I'll be able to get her running again. Though the wife thinks I should take it into a shop. Would rather do the work myself, but sometimes I do know my limits. ![]()
nice start to a good project what year is it? keep us posted on progress
vinnie 1960 chevy c10 frame with a 1966 cab 2002 dodge intrepid r/t 2004 chevy 2500 4 door short bed |
#7 | |
![]() ![]() Progress is gonna be kinda slow for a while. Just trying to get it to where I can drive it for now. Then it'll go into storage while I'm stationed in Germany for a couple of years. While I'm over there I'll be saving up and making plans so when I get back, I'll have a nice plan for doing a a Frame-Up custom restomod ![]()
DDOV
u need a new motor. sounds like it to me atleast
If you don't like the way I drive, stay off the sidewalk http://67-72chevytrucks.com/vboard/s...d.php?t=317070 The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself? |
God I hope not, at least not yet. Was thinking it might be the carburetor, but not sure.
TexasBowhunter
If it runs at high idle and only on choke.....it sounds like your low speed jet is clogged.
Rebuild the carb. Nice project!
Build in progress for son's first truck. |
Tot Roddin'
Nice looking project, good luck!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#12 | |
1962 C-10
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
#13 |
KOOL TRUCK! GLAD TO SEE YOU BRINGING IT BACK TO LIFE!
![]() Bowties For Life!🇺🇸 |
#14 |
Thanks! Been in love with these trucks since my first one. Been regreting getting rid of it since the day I sold it. Been looking for one for a while now. Glad I found this one.
Plan to eventually upgrade the engine/transmission, but not sure yet what i'm gonna go for. I love the look/feel of a inline 6, so I'll probably upgrade to like a 292 with TBI, etc. and a 5 spd manual. Think it definatly needs a new rear end gear. Will also upgrade to disc brakes. I like the current stance, but think I might get some 1" drop coils to lower the front just a tad for a bit o' rake. Thinking for paint, either a dark green maybe with pearl, or a Really dark (think eggplant) purple.
#15 |
nice start man. first thing i ever do when i get one of these old trucks is rebuild the carb. seriously, every time, once ive done that those little sixes fire right up, stick with the I6's a 292 right now with a powerglide and powersteering. i love it!! keep us posted
