Old 10-09-2008, 06:23 PM   #1
dolphman88
DDOV
dolphman88's Avatar
Lowering???!??!?!?!
how much can a truck be lowered by heating the springs? does anyone know, or has anyone done it and have pictures?? thnks
If you don't like the way I drive, stay off the sidewalk
http://67-72chevytrucks.com/vboard/s...d.php?t=317070
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
dolphman88 is offline   Reply With Quote
Old 10-09-2008, 08:03 PM   #2
leftcoast66
leftcoast66's Avatar
Re: Lowering???!??!?!?!
Cutting coils is a method I'd much prefer. One full coil cut out is roughly 2" drop. Not sure what to do about the back, but heating I've heard many more bad things than good things about.
leftcoast66 is offline   Reply With Quote
Old 10-09-2008, 09:20 PM   #3
tiggamonsta
tiggamonsta's Avatar
Heating the coils will degrade the strength of the steel. I would not want to see one of these trucks on the highway when a spring breaks from being heated.
tiggamonsta is offline   Reply With Quote
Old 10-09-2008, 09:25 PM   #4
MEANlowGREEN
Registered Asphalt Offender
MEANlowGREEN's Avatar
Yes, you definitely don't wanna heat them. That takes the temper out of the spring and ruins the ride and it can be dangerous. Cutting springs is better but if you are starting out with a set of 40 year old springs it still won't ride great. Drop springs are engineered to give you the best ride possible with the shorter length. I went from old springs with one coil removed to 2 1/2 drop spindles and 3 inch drop springs up front and 5 inch drop springs out back and my ride improved greatly even though the truck now sits much lower than it did with one coil removed from each coil. The good thing about cutting springs though is that it's basically free so try it and if you don't like the ride then plan on stepping up to true drop springs. The important thing is that you are getting low!
MEANlowGREEN is offline   Reply With Quote
Old 10-09-2008, 11:11 PM   #5
dolphman88
DDOV
dolphman88's Avatar
cut.. ok. ill trial and error until i like it. right?
Old 10-09-2008, 11:34 PM   #6
TimE
Hey Y'all!!
TimE's Avatar
The only coils that can be cut are the fronts. The rears are tapered on both ends.
TimE is offline   Reply With Quote
