Old 10-13-2008, 10:34 AM   #1
hotrodxy
hotrodxy's Avatar
73-87 disk brakes on a 67-70
I want to put power disk brakes on my 67 chevy c10 (69 rolling chassis) and I'm on a tight budget, can I get 73-87 parts from a junk yard, are they interchangable? If so what parts wood I need? Any help would be apriciated
1967 LWB 4speed-current project
1970 LWB 3 speed -stolen
1980 Z28 - sold
1968 Barracuda Big block- sold
1969 Firebird 400/400-sold
hotrodxy is offline   Reply With Quote
Old 10-13-2008, 11:43 AM   #2
SCOTI
SCOTI's Avatar
Re: 73-87 disk brakes on a 67-70
Yes, all the parts are interchangeable. You can use the a-arms, spindles, rotors, calipers, drag-link, tie-rods, rubber lines, hard lines, & prop valve.
I bought the arms, calipers, spindles, splash shields, master cylinder, pwr. booster, prop valve + hardlines, & the drag-link from a wrecked truck when I did this swap on my 68.
I used the master cyl, booster, & calipers as cores toward new parts (the master cyl & booster I exchanged for 71-72 year model). The brake lines had to be slightly tweaked but fit & look factory. The prop valve was relocated to the front splash pan vs under the master cyl like 67-72's but since I grabbed the hard-lines that was just an R&R excersize.
On my truck I re-used the original steering box because I was keeping it manual steer, but you can use the pwr box from the donor as well if you didn't have pwr steering (although 67's require some additional bracing @ the inside of the frame).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-13-2008, 11:48 AM   #3
hotrodxy
hotrodxy's Avatar
Wow thanks!!!!
1980 Z28 - sold
Old 10-16-2008, 09:54 AM   #4
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
I did the samr thing but was wondering what coil spings to use. I have a pair of 2'' lowering coils from a 68, will they work in the 73-87 arms?
68? It's all figured out untill you get it apart.
Is it Sunday yet???
68 Project
68 SWB frame off/98 Vortec with stock FI/power everything.
95 ECLB 2500 with 346,000 on the clock(the original HD)
99 Lesabre-wifes ride
08 Crew Cab LTZ-All Mine
89 SWB 5/7 drop-Son's first ride.
TEXAS 68 is offline   Reply With Quote
Old 10-16-2008, 09:58 AM   #5
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
If your get the chance, get the 1-1/4" wide rotor brakes instead of the 1"
Also, try to get as much of the system as possible
I do believe that the upper ball joints are different, but the lowers are the same
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 10-18-2008, 07:45 AM   #6
bobbo
Droppin' It Like It's Hot!
bobbo's Avatar
Excellent information here. I might be acquiring an 85 C10 and was wanting to convert my 69 over to the disc brakes. I was thinking about swapping over the whole cross member, but if the a-arms and spindles will swap then I will just do that. Anyone know if the rear end assembly will swap over or what modifications would need to be done? The 85 is leaf spring and mine is coil spring. I want the five lug axles out of the 85 to match the front disc. Would it be easier/possible to just swap the axles and/or gears and axles? Any other pointers would be great!
Robert
Life Member
RIP CAROL JANICE HARTMAN. BELOVED MOTHER. 01/04/53 - 03/05/09
1969 1500
Norwood, MO 2007
Big Sandy, TN 2008 Had nothing to do with the forklift!
Kirkwood, MO (Midwest Meet 2009)
Midwest All Truck Nationals, KCMO - 2008 - 2009 - 2010 - 2012 - 2014
SUPPORT THE SITE HERE!
bobbo is offline   Reply With Quote
Old 10-18-2008, 10:39 AM   #7
SCOTI
SCOTI's Avatar
The rear end is slightly wider than your 69 coil rear but it will fit (it's the same width as a 71-72 rear housing).
ECE & CPP both make the needed brackets for the swap. You'll need to cut off the leaf related brackets & weld the trailing arm related brackets on (after determining your pinion angle & making sure everything is centered).
Another option is both of those companies make axle swap kits that allow removing your 6-lug axles & swapping in new, aftermarket, 30% stronger axles. I like this method & feel it's easier than all the swapping, grinding , & welding req'd when swapping to the leaf spring housing. If your on a tighter budget & don't mind the labor, swapping the housings you already have would cost less.
For the record..... If you don't mind the 6-lugs, several board vendors sell 6-lug rotors that will work w/the disc swaps. The only downside is when you need new rotors, you can't run down to your local parts house. This is the easiest way to get matching lug patterns. They're about ~$20 more than regular 5-lug rotors but save you a bunch of work.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-18-2008, 12:08 PM   #8
bobbo
bobbo's Avatar
That is a good option as far as the 6 lug rotors...Have any names of the board members that sell them?
Robert
Life Member
1969 1500
Norwood, MO 2007
Old 10-18-2008, 12:16 PM   #9
SCOTI
SCOTI's Avatar
Classic Heartbeat (Wes)
GMC Paul
ECE
CPP
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-18-2008, 03:07 PM   #10
bobbo
bobbo's Avatar
Thanks for the info! Will have to wait until Monday to hear if the guy is wanting to sell the 85. I doubt he is going to fix it since it's going to be about a grand to do head gaskets and not knowing if the heads are even good. i may be able to pick it up for a few hundred...
Robert
Life Member
1969 1500
Norwood, MO 2007
Old 10-18-2008, 07:20 PM   #11
XXL
Seņor Member
XXL's Avatar
Yes.
XXL is offline   Reply With Quote
