Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 10-13-2008, 05:51 PM   #1
smoky02
Location: Sunny, Florida, some might call it South Alabama
Radio
I'm installing an after market CD player in my truck and at the moment i don't have any speakers or any wiring in my truck. The factory wiring was eaten up pretty bad so I just pulled it out. My question is what all will i need to install this CD player? How much wire, sizes and what not.
Thanks in advance,
B.
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 10-13-2008, 07:04 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Radio
Depends on where your putting your speakers. I put two in each door and bought 2 20' rolls of speaker wire and had a bunch left over. I needed about 7'-8' of I forget what gauge wire, (maybe 10 or 12 gauge), for the power on my particular CD player.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 10-13-2008, 08:20 PM   #3
kamikazekyle05
kamikazekyle05's Avatar
Re: Radio
Well you need a positive and ground for the cd player, the wire for 12 volt switch(when you turn the key on) and positive and ground for each speaker, i know im forgetting something, but that should give you an idea
kamikazekyle05 is offline   Reply With Quote
Old 10-13-2008, 09:02 PM   #4
smoky02
Re: Radio
Thanks you guys. I'm putting kick panel speakers in.
Old 10-13-2008, 09:02 PM   #5
smoky02
Re: Radio
Also, how did ya'll support the back of your CD player?
Old 10-14-2008, 06:11 AM   #6
AceX
>130dB Moderator
AceX's Avatar
Re: Radio
You can support the rear of the deck with a small bracket. I use small metal strips with precut holes. For the life of me I can't remember what it's called exactly...
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 10-14-2008, 08:48 AM   #7
faribran
Re: Radio
K...that's what i was thinking
faribran is offline   Reply With Quote
Old 10-14-2008, 08:49 AM   #8
smoky02
Re: Radio
LOL...sorry about that, my dad was the last person to log onto the computer. Faribran is his name.
Old 10-14-2008, 06:57 PM   #9
72 cheyenne pdx
72 cheyenne pdx's Avatar
Re: Radio
You'll need 12V constant, 12V switch, ground, and speaker wire. The power/ground should be at least 14ga, but recommend 12ga. The speaker wire should be minimum of 18ga (usually comes with the speakers), but then again I would recommend 12ga as well. If you are using a cage, you could get away from using the back strap, but the back strap usually comes with the head unit if you want to use it. You can get away from using a switched power and wire the switched wire on the stereo together with the 12V constant and then you will have to manually turn on/off your stereo or remove the faceplate.
Good luck with the build and show some pics were you are done.
72 cheyenne pdx is offline   Reply With Quote
Old 10-15-2008, 12:01 AM   #10
smoky02
Re: Radio
Thanks all, and the CD player is in and sounds good, I'll post up some pics tomorrow
Old 10-15-2008, 01:49 PM   #11
AC72
AC72's Avatar
Re: Radio
i'm in the same boat, thanks for the thread. check out my idea for some highs in the vents in other post. i think the strap material is called plumbers tape. good luck, keep us posted.
AC72 is offline   Reply With Quote
