Old 10-29-2008, 04:34 PM   #1
old fart
old fart's Avatar
1970 K10 front axle noise
I use this truck to plow my driveways. I got it before the first snow last year. I have a loud continuous banging when I am under load. Comming from the front wheel on the passenger side. I put off fixing it untill now. When I pulled the hub I noticed that the hub nuts were loose. I was able to turn them out using a dental pick. I read that you should torque the first nut to 40 lbs with a torque wrench. The sound, I am guessing , was that tire going in and out of 4 wheel drive. I took the axle out and the splines are fine. Could my problem be that nut was not all the way in? Or could there be a problem with the warn locking hub? Maybe it wasn't turned all the way in? I am grabbing at straws here. I looked at the ujoints and they look new and move nice with no loose play. If I can't figure this out I will have to put it back together and wait for total failier then I will replace what breaks. Any input is appreciated!!
1970 k10
1967 C10 parts truck
old fart is offline   Reply With Quote
Old 10-30-2008, 08:48 AM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: 1970 K10 front axle noise
The first nut gets torqued and then backed off 1/4 turn to give the wheel bearings .001 to .010 play. The second nut gets torqued tight.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
axel, hub
