Old 11-11-2008, 02:19 PM   #1
PMS
Door seals
Does anyone sell door seals that last as long as original? I am also looking at front / rear window seals. I purchased aftermarket and they didn't hold up very long. 72 GMC
PMS is offline   Reply With Quote
Old 11-12-2008, 12:46 AM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Door seals
There are several different brands available.What brand did you use that were not satisfactory.I would guess Steele as the best since they do weather seals for just about any domestic vehicle ever built.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 11-12-2008, 09:58 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Re: Door seals
I bought the push on type from GMCPaul and they are easy to install.
pn 2660241--- 1967-72 Door door opening weatherstrip attaches to cab and seals door to cab, sold in pairs. A Glue Less, Push-on Alternative to factory 67-72 door seals. These push on, and will conform to the stock 45 degree mitered corner above the vent window assembly. And the more bulbous seal, seals tighter than 67-72 factory replacement seals , the exposed part of the seal on the inside the cab is much cleaner looking also. For Pickup doors only. LIFETIME WARRANTY To Original Purchaser Manufactured By Precision.
68gmsee is offline   Reply With Quote
