Old 11-11-2008, 11:45 PM   #1
Gregs67
Will the carpet lay right over the high hump?
I am building this 67 2WD step using a 70 4x4 cab. I re-installed the high-hump, making a cool little cover for the 4 speed hole that follows the contour of the high hump stamping. (flat then sloping upward.)
We will be keeping it auto on the column for now, and wanted to use the high hump for a B&M rat**** shifter in the future. Our concern is this: Will the new ACC carpet lay smoothly over the shifter hump ("high hump) and is the 4 speed cole covered up or is it pre-stamped in the carpet? Hoping there isnt a hole there.
thanks!
Gregs67 is offline   Reply With Quote
Old 11-12-2008, 12:12 AM   #2
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: Will the carpet lay right over the high hump?
Just make sure that you order high hump carpet not low hump and you should be fine
The carpet I have seen has little to no forming
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 11-12-2008, 06:54 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
no hole, and the carpet should hug the hump quite fine
Old 11-12-2008, 10:05 AM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Your vendor should ask if the carpet is for a high hump or low.The high should work perfect.Make sure you lay it out in a warm place to relax before installing.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
