Truck suddenly making horrible starter grinding noise?
Leaving my friend's house late tonight, after watching the Jets vs Giants game, go to start my truck and it developed a horrible high pitched grinding noise when I start it. I know the starter has shims, but these were installed a year ago with great operation. 87 silverado 305
I haven't pulled it apart yet, it's very late and I have work tomarrow morning. Should I be safe driving to work? Is this a symptom of a starter just getting old? This sound just developed randomly. I did get under the truck when I parked it to make sure the starter wasn't loose, it is tight. Last edited by chevymotocross; 11-14-2008 at 12:48 AM. |
Re: Truck suddenly making horrible starter grinding noise?
I had the exact same reaciton when i heard it the first time. I found that changing the tranny from park adn then back again, then trying to start it again always works. I still can't figure out why it does it....
BRAD
2000 GMC Sierra EXT Cab Short 4x4, finally mine... 1966 C10 SWB Fleet, 250 I6, three on the tree.... Previously Owned.... 1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4.... 1972 Chevy LWB Fleet 350/350 EXTENDED CAB ALL THE WAY! .._..~...-...._...____ .._..-...______|_|__\____ ..-..~.|_(O)__|_|__|_(O)] |
Yea but it still makes the sound. I start it this morning, and it still has that horrible sound when turning over. Haven't looked at it yet but I don't think it could be a shimming issue. If it were, it would have been grinding all this year, not just suddenly.
I'm thinking hopefully just a starter going bad and not a bad flywheel. |
my mini starter went out and took my fly wheel with it. If it keeps grinding, inspect it before you do any more damage.
Robert Olson Transport
![]() Join Date: Oct 2002
prolly the solenoid on the starter is getting bad.. thump is right youneed to get that starter out before you damage the flywheel ...
![]() Join Date: Jun 2007
I agree. I've had this problem before as well. If you don't fix it now, you'll end up having to pull the tranny to replace the flywheel as well. ...Joe
I'm not speedin'! I'm qualifyin'! |
Picked up a Napa Premium starter. Mechanic friend of mine told me to stay away for Autozone, Pepboys, and Advance Auto starters. I inspected the flywheel, looks fine. Will be putting new starter in Sunday. Hopefully it solves to problem and I will let you guys know the results! Thanks
New starter solved the problem. Thanks guys!
your firend is right abd out autozone and pep boys those idiots cant give you the right part properly rebuilt if their lives depended on it.. ive had no problem with autozone or napa but id do my best not to buy out of those other two
glad to hear it wall worked out
Chevys Kick A$$
Thats good. I will be getting a new started on my truck next week or two mine is doing the same exact damn thing.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
I'd almost guarantee the starter drive was cracked if there's no flywheel damage. What happens is when you engage the starter the solenoid pushes the drive out, then when the gears engage the resistance makes the drive skip and strip ove the internal gears. It happened in my Chevelle and had a local shop fix it.
1986 Chevy 3/4 Ton 4X4 ![]() |
#13 |
What Hump?
My 454 was making a horrible grinding noise, removed the cover and found out the convert came loose. So check everything.
Tom
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
#14 |
also look at the neralled part of the starter bolts...if they look like they have been smoothed out by the starter, replace them too....had a caprice that made the same noise and finally pin pointed it down to the starter bolts...
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you." '84 chevy half ton short box 2wd, 67,000 actual miles ![]() '03 chevy 1500 HD crew cab 4x4 standard box, 6.0L ![]() ![]() ![]() |
#15 |
Active Member
![]() Join Date: Apr 2019
Bringing this one back from the dead with a similar issue.
I've put 4 or 5 starters in this thing and it seems like I get about a month out of it before it gets weaker, starts grinding, and eventually stops working entirely. I'm just not sure where else to look. New starter New 1 wire alternator New battery Still got 30 days out of it. (it was perfect for about 3 weeks, then started acting up. Now it's grinding loudly) Help!!!! 😁 😁 😁 |
#16 | |
#17 | |
Active Member
Now I'm running a smaller starter out of a 2003 3500 with the 8.1 litre and I STILL only got a month out of it. I'm not sure where else to look or what else I should change. Could a short of some sort cause it? A draw? So not wanting a 6th starter.... |
#18 |
I would look into the flexplate may be bent or missing teeth
#19 |
Active Member
