11-14-2008, 11:23 AM | #1 |
need aol. answers
I,m getting ready to try and to a aol setup on my 78 blazer,found some pics but I have staggered shocks,what to do.More pics would be nice too thanks
11-14-2008, 03:56 PM | #2 |
Re: need aol. answers
I found some more pics and all the shocks have been moved inside frame rails,is there a kit for this or does someone have some good pics so I can fab this up
11-14-2008, 07:27 PM | #3 |
Are you doing an AOL for capacity or are you removing leafs in combo w/the AOL to just get it lower?
11-14-2008, 07:42 PM | #4 |
I,m trying to do the ntrux setup,I,ve notched the frame and am trying to see where i,m going to sit with removing some leafs and a block if needed,but I see the shocks are staggered and the photo of nutrux frame there is only a pic with only 1 shock installed,not done yet of course,so I,m trying to see where to locate other shock
11-14-2008, 11:08 PM | #5 | |
11-15-2008, 12:11 PM | #6 |
was n,t there bottom plates ,where the u bolts go thru,made with a shock mount on it?I recall them along time ago,this setup might work instead of welding,All I have is a 110 wire feed welder
11-15-2008, 10:10 PM | #7 |
I've seen shock plates like that for cars but no trucks. Call AirRide & see what they suggest. Perhaps they've got a solution that doesn't require welding a new bracket.
11-16-2008, 11:28 AM | #8 |
Thanks for the help,I,ll see what I can come up with
