Old 11-25-2008, 05:03 PM   #1
Old Bluey
Old Bluey's Avatar
67 Short/Fleet Tonneau Cover
I got tired of searching for a tonneau cover for my truck only to find some modern fiberglass thing, or flimsy "knife-able" material. I'm lucky enough to have a rust free bed and wanted to protect the box, and maybe grab a few mpgs while I'm at it.
Here's what i got:
1) Tonneau cover vinyl - $70-$100 bucks from a fabric distributor
2) 2 x 12" Stainless lag bolts w Washers/Nuts (front retention) $10
3) 2 x Custom Cut 3/4" Plywood, sanded, good one side $100
4) Hood Pin Kit (Rear retention) - $15
5) Wood sealer (Thompsons water seal - $20
6) Staple gun, Fabric Glue, Router with a nice 1/2" curved bit.
7) 4" strips of laminant insulation for the bed rails.
It cost me about $250 (including the beer) and it turned out allright. If you have a buddy who knows upholstery, you could extend the life of the project with a better hinge seam or professional corner wraps. But this one looks great from 2 feet away, and does the job I need it to.
Check it out:
Measured up and cut the piano hinge
Hood Pins!! (screwed into wood, retained in the corners)
Gluing the cover down
The ripples are completely gone and the cover looks tight. I'm going to search out some hatchback rams to mount inside to help lift the cover and hold it up. At present, you can flip it over and lean it on the back of the cab.
Old Bluey is offline   Reply With Quote
Old 11-25-2008, 07:01 PM   #2
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: 67 Short/Fleet Tonneau Cover
Neat
I plan to make a custom tonneau for my truck also
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 12-03-2008, 05:51 PM   #3
67mater
67mater's Avatar
is that a 70 impala in the garage?
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 12-03-2008, 06:20 PM   #4
Old Bluey
Old Bluey's Avatar
Nope, its an empty 71 Skylark awaiting a 455/TH400. It's going thru a transformation to become a really nice GSX clone.
Old 12-03-2008, 07:05 PM   #5
67-72crazy
67-72crazy's Avatar
sorry i can't help i just wanted to say i like your truck
1991 1500 longbed: my daily driver
1937 chevy 2dr sedan. dads project
67-72crazy is offline   Reply With Quote
Old 12-03-2008, 07:13 PM   #6
Old Bluey
Old Bluey's Avatar
Thanks! It's a great running project. Power Steering is going in next week, and I've got a little T5 trans on its way to bolt up to the 250. That overdrive will be a big help.
