64-66 CHEVY JUNKIE
Can anyone I.D. this gas tank?
Can anyone i.d. this tank? Im thinking about using it between the frame rails in the back. Its 30in long x 19in wide and 13in tall with a 1 1/4 O.D. filler pipe. Its a bit rust on the outside but the inside is good and clean, I want to buy a sending unit for it but i dont know what it come out of, I got it from someone who dont know what it come out of. Any help would be great, Thanks Chris..
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E ![]() ![]() |
64-66 CHEVY JUNKIE
Re: Can anyone I.D. this gas tank?
[IMG]
64-66 CHEVY JUNKIE
[IMG]
64-66 CHEVY JUNKIE
[IMG]
60-66 Nut
![]() ![]() Join Date: Mar 2007
It looks to me like a '69-'72 Blazer tank, which is what is the popular one to retrofit into these trucks. If it has a rounded indent on the lower back side for the spare tire then it is out of a '63-'66 Suburban. IIRC if it is a Blazer tank you'll need to switch the sending unit to a 0-30 ohm sender. Someone correct me if I'm wrong on that.
Captain.........................I believe you ars correct.............took the one off of my burb and it had the indent for the spare................replaced it with a new one from a blazer ...................it was a good investment...............Hemmit
64-66 CHEVY JUNKIE
Thanks, is the 0-30 ohm sending unit in a 63-66 burban tank........If so will it fit in the blazer tank with out welding or mod.......Thanks Chris........
Yes, the 0-30 ohm sender is what you need for a 63-66 ...Not sure if it's the same size as the one for the blazer tank.................you might try calling gmc paul and ask him to measure a tank for you to compare......Hemmit
64-66 CHEVY JUNKIE
Thanks Demmit 4........ your help. I better find out before i buy one and it dont.........fit the tank i have , Do you have any pics of your tank or wow its mounted?......... for ideas to hang mine....... Chris........
Gulf..............When i get a chance i'll go out and get a picture of mine mounted on my burb for you so you can see how mine is mounted........Hemmit
64-66 CHEVY JUNKIE
Thanks Demmt,.............I appreciate it ......Chris
60-66 Nut
The best I can tell is the Blazer tank is aprox 1 1/4" deeper than the '63-'66 Suburban tank. The sending unit flange is the same however. Most of the truck parts suppliers will have the 0-30 ohm sending unit for the Blazer tank.
Here's what LMC has, but it doesn't specify that it is 0-30 ohms. It is however listed for '63-'66 trucks. http://www.lmctruck.com/ICATALOG/CBE/full.aspx?Page=71
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 12-11-2008 at 12:19 AM. |
