![]() Join Date: Oct 2008
replacement panels
Hey guys. I need to replace my rocker panels and outer cab floor on my 64. I usually try and go to LMC for most parts but they are pretty pricey compared to some other sites. Especially on the outer floor panel. About $45 more. Is this a case of you get what you pay for or am I overpaying?
Re: replacement panels
I believe classicparts.com carries the same stuff and it is less expensive.
![]() ![]() Last edited by joe231; 12-15-2008 at 10:50 AM. |
It's Better With Nitro
X2...that's where I just purchased my rocker replacement panels. I have to do the same thing on the driver's side soon.
Personaly I like to use the OEM rockers but I don't think they are available any longer from GM. Could be wrong though.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
