12-22-2008, 03:14 PM | #1 |
Guys with 15x10 Wheels - Inside Please
What backspace are you running? And what tire sizes? Pics are welcome too. Thanks!
12-22-2008, 04:19 PM | #2 |
like a rock
Re: Guys with 15x10 Wheels - Inside Please
4.5 inch backspacing with 295/50/15. I don't have these on now because of the lack of drop and the little tires make things looks out of place.
12-22-2008, 07:00 PM | #3 |
Thanks Vern - looks great to me even as-is. Anyone else?
12-22-2008, 07:27 PM | #4 |
I have 15x10 with 275/60/15,4.5 BS
12-22-2008, 07:47 PM | #5 |
The One And Only !!!
Here's a pic of my 74 before stripping it down to the frame.
15X10 4.5 spacing with 295/50's with just a drop shackle kit.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
12-22-2008, 08:56 PM | #6 |
Here is mine 15x10 4.5 back space with 29x15x12.5 tyres
77 Cheyenne no longer in bits |
12-23-2008, 12:22 AM | #7 |
Rear 15x10 4 inch BS, P275/60
Front 15x8 4 inch BS P245/60 But these are coming off soon. [IMG][/IMG] Last edited by Nolowrider; 01-23-2011 at 08:35 PM. |
12-23-2008, 12:53 AM | #8 |
Its not a 15 inch wheel , but it is 10 inches wide with a 275/60/17 tire and a 4.5" backspace. It will give you an idea of where the wheel will ride in relation to the fenders .
Frank
Born and proudly residing in a Red State ! |
12-23-2008, 06:21 AM | #9 |
>130dB Moderator
I'm sure alot of people are tired of seeing mine, but I'll add to the roster.
15x10 all around. Backspacing unknown. Tires are 255/60/15 in front and 275/60/15 out back. Suspension has a 2/4 drop. Thr fronts rub slightly.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
12-23-2008, 11:52 AM | #10 |
12-23-2008, 12:04 PM | #11 |
so frim what im reading here, a 4.5 backspace would be the way to go with the 15x10 wheel.
76 Chevy shortbed C-10, 350 w/turbo 350 trans(under construction) cardomain page: http://www.cardomain.com/id/DmestcDisturbnce |
12-23-2008, 12:52 PM | #12 |
Unless you lower it a lot, or have a really wide tire. I have custom 6.5 backspace 15x10, with 29x15.5 Mickey Thompsons, they fit perfect and never rub.
12-23-2008, 01:03 PM | #13 | |
US Army Veteran
I do have a couple of questions: 1) Is the 2/4 all you've done? No drop springs? I ask, because this is exactly how I'd like to do mine. What brand of spindles are you using? 2) Not knowing the backspace, let's assume for a moment it's 4.5 for the purpose of my question. If it were 4.5 and wheels with a 5.25 backspace were swapped out, would that "tuck" the wheels into the fender more, or push them out past the fender?
1972 C10 Highlander - The making of a daily driver |
12-23-2008, 01:26 PM | #14 | |
oh and sorry for the thread jack
76 Chevy shortbed C-10, 350 w/turbo 350 trans(under construction) cardomain page: http://www.cardomain.com/id/DmestcDisturbnce Last edited by DomesticDisturbance; 12-23-2008 at 01:27 PM. |
12-23-2008, 01:49 PM | #15 | |
Parts and more parts
I agree with this setup. I have Billet Specialties rims and I have a set of 17" rims with the rears being 17" X 9.5" with a 4.5 backspace. Plenty of clearance on the spring. |
12-23-2008, 02:03 PM | #16 |
12-23-2008, 02:18 PM | #17 |
I need to get some good overall shots of the truck, but here are some to show the fit.
Still need to put wider wheel tubs in the bed after butchering it in the dark. Last edited by Richard D; 12-23-2008 at 02:20 PM. |
12-23-2008, 09:35 PM | #18 | |
>130dB Moderator
Larger backspacing will push the wheels out.
12-23-2008, 10:43 PM | #19 |
To answer the couple o questions about my wheel setup , it might rub if I lowered it a couple more inches . My 18x10's I had on the tan truck were 5.25 inches of backspace and fit real nice . The tires are 275/60/18 Nitto's . This truck was only lowered 2.5/4 . The 15x10 with a 275/60/15 will fit the same but is just shorter overall because of the wheel diameter. I ran 15x10 Convo Pros with the same size tire years ago and they had a 5" backspace . Centerline listed it as a 4 7/8" backspace and it was perfect on a 15 inch wheel .
Frank
12-24-2008, 08:48 AM | #20 |
12-24-2008, 09:37 AM | #21 |
yeller
You beat me to it, I was going to say the same thing.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
12-24-2008, 10:52 AM | #22 |
I have 10x 15 589 eagle alloys all around with 295/50 and 265/50 Bfgs but i canīt tell you the backspacing,sorry! The papers say ET -45 mm but i canīt tell what that means!
My little US vehicle parts business: http://www.thegearheaddepot.com/ Come have a look! ī81 GMC C 10, Spanish Red |
01-08-2009, 11:53 AM | #23 |
moneyeater, what size drop do you have? That looks great
01-08-2009, 12:57 PM | #24 |
-Lincoln 1987 GMC S15 (soon to be a chevy clone) 2.5l, 4 speed, no ps, no pb, no ac Silence is golden, but duct tape is silver. Spoken by Cletus the hillbilly I like stickers... a whole bunch. Last edited by abebummy26; 03-31-2010 at 06:34 PM. |
01-08-2009, 01:14 PM | #25 |
Thanks for the reply
