Old 12-27-2008, 09:47 PM   #1
sgtusmc
sgtusmc's Avatar
thermostat question
I had some overheating issues. I removed the thermostat out of my 53 GMC(2.8 V6) It looks like it's the stock thermostat from 88 and it's stuck in the closed position. My question is, If the truck is only driven in the summertime, do I really need a new thermostat or could I just run the truck without one? I'm not try'n to be cheap. I know there not expensive. I just thought I'd see if anyone is running without one. What should I do, replace or not use one? Sorry if this is a stupid question.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 12-27-2008, 10:25 PM   #2
pugs
pugs's Avatar
Re: thermostat question
i ran alot of old vehicles with one for alittle bit but i would put one in, maybe a 180 or 165 degree
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 12-28-2008, 05:34 PM   #3
OrrieG
OrrieG's Avatar
Put it in, it is there to regulate temperature, it allows the engine to warm up in winter and let water flow through radiator and engine to cool efficently in summer.
OrrieG is offline   Reply With Quote
Old 12-28-2008, 10:03 PM   #4
sgtusmc
sgtusmc's Avatar
Thanks for the help guys. I picked one up today.
Old 12-29-2008, 02:45 PM   #5
mylow53
mylow53's Avatar
depending on your set up if you run the average modern car/ truck with out a thermostat your engine won't reach the recommended temp. and may run rich lowering your milage. also since the parts are designed to expand with heat your engine will wear slightly more. you made the right choice
GT
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
