Old 01-02-2009, 01:31 AM   #1
C10Sim
C10Sim's Avatar
"La Veija"
Quick summary:
1968 C10, 454 BB
I bought my truck around late Sept 2008.
I bought an addtional frame to start the bag work.
Then I started replacing part: Conversion kits, cab corners, shaving fenders and so.
Took about 3/4 of an inch bondo from roof and rear middle cab. Then Decided to buy an original, no body work done cab.
Puchased a Dropmember....
So here it goes.
C10Sim is offline   Reply With Quote
Old 01-02-2009, 01:35 AM   #2
C10Sim
C10Sim's Avatar
Re: Project "Dirty D"
Started to shave fenders and gas hole
Old 01-02-2009, 01:37 AM   #3
C10Sim
C10Sim's Avatar
Replaced the cab corner, which it went pretty smooth.
Old 01-02-2009, 01:40 AM   #4
OARNGESI
OARNGESI's Avatar
Nice progress
OARNGESI is offline   Reply With Quote
Old 01-02-2009, 01:40 AM   #5
C10Sim
C10Sim's Avatar
I discovered that my grill had a thick layer of bondo, so I cut the center stip that was bent and replaced with another.
Old 01-02-2009, 01:46 AM   #6
C10Sim
C10Sim's Avatar
Well I purchased this frame for $100 at a swap meet and water blasted it. It is only temporally, once frame gets bagged, it will be sent out for power coat.
Installed a 6 lug conversion kit.
I purchased a Dropmember from Nate.
This means all new springs, spindles, ball joints were pointless
Old 01-02-2009, 01:55 AM   #7
C10Sim
C10Sim's Avatar
Well on New Years of 2009 I installed my dropmember, and 2 weeks before that I purchased a another cab because my truck cab had bad deep dents that had been badly work and it had to much streched metal. I decidedto buy a cab that had original paint job, that way I knew exactly what I was getting into. The good thing is that the cab corners dont need replacement but the rockers do (It ok because I was going to replace them on the other truck aswell). The floor need replacement but only a small place on driver side. Roof is in excellent condition
I am not done cutting the frame for the rack and pinion. I wanted to confirm it with Nate before anyrhing.
I will try to keep posting.
Old 01-02-2009, 11:06 AM   #8
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Lookin good! Keep up the good work! What kind of welder do you use?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 01-02-2009, 11:46 AM   #9
C10Sim
C10Sim's Avatar
Its a Millermatic 130 XP. It works great but I am starting lean over the lincoln 135-140 it sound beatiful compared to my Miller (Maybe its just my machine). I will be getting a Lincoln today.
1968 Chevy Pickup
http://67-72chevytrucks.com/vboard/s...d.php?t=321717
1959 Chevy Apache 3100 SWB Big Window
http://67-72chevytrucks.com/vboard/s...d.php?t=597069
Old 01-04-2009, 06:51 PM   #10
royo
royo's Avatar
kool
nickle and dime
royo is offline   Reply With Quote
Old 01-15-2009, 03:19 AM   #11
C10Sim
C10Sim's Avatar
Well I finally cut the frame to get clearence for therack and pinion.
1968 Chevy Pickup
Old 01-15-2009, 03:23 AM   #12
C10Sim
C10Sim's Avatar
Since I had the welder out, I went ahead and shaved the gas hole.
Phillip13 Donated the gas delete panel, Thank You!
1968 Chevy Pickup
Old 01-15-2009, 03:26 AM   #13
C10Sim
C10Sim's Avatar
This is the cab that I purchased for $50. Needs work but looking forward to it.
This just some of the rust that needs replacement. I will update as I finish a section.
1968 Chevy Pickup
Old 01-15-2009, 03:31 AM   #14
C10Sim
C10Sim's Avatar
I have started to shave the drip rail and replacing the rockers and pillars.
1968 Chevy Pickup
Old 01-15-2009, 07:53 AM   #15
ANTHONY67
man thats looking good
ANTHONY67 is offline   Reply With Quote
Old 01-15-2009, 09:20 AM   #16
thirdstreettito
Resident of Here
Lookin good! Keep it up!
~Bradley~
Miss having a truck
Old 01-17-2009, 10:25 AM   #17
phipp13
THE DAMN YANKEE
phipp13's Avatar
Very nice, you do good work! Is that a DAMN YANKEE cab fuel tank delete panel?? LOL Phipp
phipp13 is offline   Reply With Quote
Old 01-17-2009, 12:59 PM   #18
ll____b0t____ll
ll____b0t____ll's Avatar
Looking good Im watching this one....gotta love those stepsides lol.
ll____b0t____ll is offline   Reply With Quote
Old 03-29-2009, 11:38 PM   #19
C10Sim
C10Sim's Avatar
Here goes an update March 29, 2009!
Well my business has increased, so my time is short now. I decided to get a cab that needed less work. I bought a cab off a board member and it was in real good condition. It only needs inner and outer rockers and cab corners plus my little extra areas that I want to shave.
I fab'd in new inners and coated them with por-15. Then I installed the new outer rockers.
I also bought a new raditor support, It's not as tough as the orginial but cost effective due to the work my orginial needed.
1968 Chevy Pickup
Old 03-30-2009, 12:35 AM   #20
C10Sim
C10Sim's Avatar
Went ahead and replced tthe passengers cab corner and coat the inside with por-15 aswell.
1968 Chevy Pickup
Old 03-30-2009, 12:40 AM   #21
C10Sim
C10Sim's Avatar
I really didnt want to shave the drip rails on this cab because they were in perfect condition but that's a different project.
1968 Chevy Pickup
Old 03-30-2009, 12:48 AM   #22
C10Sim
C10Sim's Avatar
I bought a short fleetside bed that had been garaged for 11 years and has no rust or body filler. The only defect is has is two door dings and a missing floor. The tail gate does need some work, but I will worry about that later.
I also bought 2 new doors from a friend that decided to go a different route (traded them for a new brakebooster)
KYB shocks and lower bag plates.
Installed a new power rack and pinion
Here is another picture of the new raditior support.
New items that are in thier way:
-wiring hardness
-step notch (porterbuilt)
-2 inch steel cowl hood
-euro headlights with trim
-new door hinges
1968 Chevy Pickup
Old 03-30-2009, 12:55 AM   #23
C10Sim
C10Sim's Avatar
I went ahead and took my motor apart and will head to the machine shop within a couple of days.
1968 Chevy Pickup
Old 03-30-2009, 07:30 AM   #24
VA72C10
VA72C10
VA72C10's Avatar
Looking good...that's going to be a sweet ride when done..Dropmembered with a BB
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-01-2009, 06:08 AM   #25
OARNGESI
OARNGESI's Avatar
Thats looking pretty good
70 SWB STEPSIDE
70 BLAZER
09 challenger
